Publications By Year
Scholar Articles Since 2015
Title Cited By Year
A corrective agentic hybrid RAG and an operations-grounded evaluation for a scientific facility
R Sainju, D Jarosz, H Shang, M Prince, RM Aydelott, MJ Cherukara, ...
arXiv preprint arXiv:2607.24663, 2026
2026
Acquisition Geometry-Assisted Whole-Group Localization of X-ray Fluorescence Maps in Optical Microscopy Images
X Yin, T Paunesku, L Copeland-Hardin, M Ralle, ZW Di, S Chen, ...
arXiv preprint arXiv:2608.18305, 2026
2026
Adaptive Beam Selection for Efficient Scanning Probe Tomography
S Dinh, ZW Di, M Menickelly
arXiv preprint arXiv:2606.21713, 2026
2026
AI-Driven Scan-to-Discovery in 20 Minutes: Automated Segmentation of Synchrotron Micro-CT at Scale
X Chong, D Abramov, P Elavarthi, E Clark, P Zwart, W Koepp, ...
2026
AlphaDiffract: Automated Crystallographic Analysis of Powder X-ray Diffraction Data
N Andrejevic, M Du, H Sharma, JP Horwath, A Luo, X Yin, M Prince, ...
arXiv preprint arXiv:2603.23367, 2026
1 2026
An End-to-End Differentiable Forward Model for High-Energy Diffraction Microscopy
H Sharma, N Andrejevic, S Zhang, M Cherukara
arXiv preprint arXiv:2607.28843, 2026
2026
APEXA: Execution-Integrity Enforcement for Multi-Agent LLM Automation of Synchrotron Data Reduction
PK Tripathi, H Sharma, A Chuang, MJ Cherukara
arXiv preprint arXiv:2609.24165, 2026
2026
Artifact-centered claim-aware observability for autonomous scientific agents
X Yin, M Du, MH Prince, MJ Cherukara
arXiv preprint arXiv:2608.18312, 2026
2 2026
Autonomous Agentic Workflows for Ptychographic Analysis and Algorithm Discovery
Y Jiang, C Shi, YT Shao, M Du, X Yin
Microscopy and Microanalysis 32 (Supplement_1), ozag053. 985, 2026
2026
Autonomous Algorithm Discovery for Ptychography via Evolutionary LLM Reasoning
X Yin, M Du, J Deng, Z Yang, Y Han, Y Jiang
arXiv preprint arXiv:2603.05696, 2026
1 2026
CoCoDiff: Optimizing Collective Communications for Distributed Diffusion Transformer Inference Under Ulysses Sequence Parallelism
B Ma, X Ding, T Bicer, P Su, D Li
arXiv preprint arXiv:2604.14561, 2026
3 2026
Cvevolve
M Cherukara, X Yin, M Du
US Department of Energy (DOE) Software, 266, 2026
2026
CVEvolve: Autonomous Algorithm Discovery for Unstructured Scientific Data Processing
M Du, X Yin, Y Luo, D Beniwal, S Tang, H Sharma, MJ Cherukara
arXiv preprint arXiv:2605.11359, 2026
2026
Datasets for Pty-co-SAXSNN: CNN-Based Deconvolution for Simultaneous X-ray Ptychography and SAXS
J McCourt, S Seifer, M Du, B Lee, J Deng
Argonne National Laboratory (ANL), 2026
2026
Distributed tomographic reconstruction with quantization
R Miao, S Aslan, E Koyuncu, D Gürsoy
Journal of Parallel and Distributed Computing, 105295, 2026
2026
Enhancing microstructural fidelity in near-field high-energy diffraction microscopy reconstruction with Noise2Void denoising
X Guo, D Beniwal, D McLain, J Almer, JS Park, P Kenesei, H Sharma
Applied Crystallography 59 (5), 2026
2026
Experiment automation agents: automating materials characterization with vision language model agents
M Du, Y Luo, S Banerjee, M Wojcik, J Popovic, MJ Cherukara
npj Computational Materials, 2026
2026
Fidelity-preserving enhancement of ptychography with foundational text-to-image models
M Du, V Rose, J Deng, D Singh, S Chen, M Cherukara
Optica 13 (1), 45-56, 2026
3 2026
FIRM: federated image reconstruction using multimodal tomographic data
G Byeon, M Ryu, ZW Di, K Kim
Computational Optimization and Applications 94 (1), 317-352, 2026
2 2026
In-situ visualization of a growing brittle crack in aluminum oxynitride using synchrotron X-rays and the double-cleavage drilled compression geometry
SF Gorske, JS Park, P Kenesei, H Sharma, J Almer, P Voorhees, ...
Acta Materialia, 122213, 2026
2 2026
Intragranular critical resolved shear stress distributions in polycrystalline titanium using in-situ point-focused high-energy diffraction microscopy
W Li, H Sharma, P Kenesei, JS Park, S Ravi, OK Celebi, D You, TB Celebi, ...
Acta Materialia, 122217, 2026
5 2026
Kβ X‑ray Emission Spectra Analysis Using Bayesian Optimization
R Ranjan, ZW Di, M Wolfman, SD Kelly, IH Hwang, C Sun
Photon Science 1 (1), 12-23, 2026
4 2026
LaueMatching: an approach for rapid and robust indexing of Laue diffraction patterns
H Sharma, D Sheyfer, R Harder, JZ Tischler
Applied Crystallography 59 (2), 2026
1 2026
MapsTorch: automatic differentiation for X-ray fluorescence data analysis
X Yin, Z Di, O Antipova, S Chen, Y Jiang, A Glowacki
Synchrotron Radiation 33 (1), 2026
2026
Materials Behavior as Mechanism Ensembles: A Probabilistic Framework for Emergent Behaviors
BL Boyce, MA Wood, K Garikipati, AE Robertson, J Larson, I Srivastava, ...
arXiv preprint arXiv:2607.27163, 2026
2026
Micromechanical and fatigue in situ synchrotron characterization of an additively manufactured superalloy with porosity
KS Stopka, JJ Solano, P Kenesei, JS Park, H Sharma, MD Sangid
Additive Manufacturing, 105260, 2026
1 2026
MIDAS: a methodological framework for high-speed high-energy diffraction microscopy data reduction. Part I: methodology
H Sharma, JS Park, P Kenesei
Foundations of Crystallography 82 (4), 2026
2 2026
MIDAS: a quantitative framework for high-energy diffraction microscopy. Part II: accuracy, robustness and best practices
H Sharma, JS Park, S Shastri, P Kenesei
2 2026
Minimising the number of edges in LC-equivalent graph states
H Sharma, K Goodenough, J Borregaard, F Rozpędek, J Helsen
Quantum 10, 2001, 2026
5 2026
On-chip Bragg peak extraction from MHz frame rate X-ray detectors using a cellular automaton architecture
S Fowler, S Strempfer, D Beniwal, M Hammer, H Shi, S Gnanasekaran, ...
arXiv preprint arXiv:2608.18970, 2026
2026
Open Alphadiffract
M Prince, N Andrejevic, M Cherukara, M Du, A Luo, H Sharma, B Toby, ...
US Department of Energy (DOE) Software, 319, 2026
2026
Operating advanced scientific instruments with AI agents that learn on the job
A Vriza, MH Prince, T Zhou, H Chan, MJ Cherukara
npj Computational Materials 12 (1), 160, 2026
15 2026
Optimizing Paths for Adaptive Fly-Scan Microscopy
Y Lu, TF Lynn, M Du, Z Di, S Leyffer
2026 IEEE 23rd International Symposium on Biomedical Imaging (ISBI), 1-5, 2026
2026
Physically constrained autoencoder-assisted Bayesian optimization for refinement of high-dimensional defect-sensitive single crystalline structure
JO Agada, A McAninch, H Day, Y Tanyu, E McCombs, SM Koohpayeh, ...
APL Machine Learning 4 (2), 2026
2 2026
Physically interpretable interatomic potentials via symbolic regression and reinforcement learning
B Varughese, TD Loeffler, S Banik, A Koneru, S Manna, ...
npj Computational Materials 12 (1), 84, 2026
4 2026
pMSz: A Distributed Parallel Algorithm for Correcting Extrema and Morse-Smale Segmentations in Lossy Compression
Y Li, M Xia, X Liang, B Wang, R Underwood, S Di, H Sharma, D Beniwal, ...
2026 IEEE International Parallel and Distributed Processing Symposium (IPDPS …, 2026
2026
Probing Non-Equilibrium Grain Boundary Dynamics with XPCS and Domain-Adaptive Machine Learning
M Cheng, B Yu, CL Fu, N Andrejevic, MT Agne, R Hanus, Q Wan, ...
arXiv preprint arXiv:2605.12194, 2026
2026
Pty-co-SAXSNN: CNN-based deconvolution for simultaneous X-ray ptychography and SAXS nanostructure characterization: J. McCourt et al.
J McCourt, S Seifert, Z Cheng, M Du, B Zhang, MR Jones, M Cherukara, ...
MRS Communications, 1-11, 2026
2026
Strategies for Deploying AI Agents in Production at Scientific User Facilities
M Du, X Yin, M Prince, Y Jiang, R Sainju, T Bicer, Y Luo, E Codrea, ...
arXiv preprint arXiv:2609.36362, 2026
2026
StreamGuard: Low-Overhead Resilience for Real-time HPC Data Streams
HD Nguyen, B Nicolae, T Bicer, A Gueroudji, M Dorier, K Chard, I Foster
arXiv preprint arXiv:2606.30848, 2026
2026
Stress and strain heterogeneity and persistence in uniaxially‐and triaxially‐loaded sandstone
S Bose, MM Thakur, G Shahin, K Shanks, A Das, JS Park, P Kenesei, ...
Journal of Geophysical Research: Solid Earth 131 (4), e2025JB033263, 2026
2 2026
Super-resolution model for overlapping peak detection and improved spatial resolution in high-energy diffraction microscopy
D Beniwal, JS Park, P Kenesei, R Kettimuthu, A Miceli, H Sharma
Materials & Design, 115917, 2026
2 2026
Throughput Estimation of Data Transport Networks from Digital Twin Measurements
NSV Rao, A Al-Najjar, R Kettimuthu, I Foster, K Chard, R Chard, ...
IEEE Transactions on Machine Learning in Communications and Networking, 2026
2026
Toward Intelligent X-ray Spectroscopy: An Agentic AI Platform for Automated and Multimodal Analysis
J Huang, X Lu, N Andrejevic, H Harb, Y Chen, SD Kelly, GE Sterbinsky, ...
APS Global Physics Summit 2026, 2026
2026
Towards Transparent Checkpointing with AI-driven Code Generation
HD Nguyen, T Bicer, K Chard, I Foster, B Nicolae
arXiv preprint arXiv:2606.30921, 2026
2 2026
Training-Free Inference for High-Resolution Sinogram Completion
J E, S Banerjee, T Bicer, G Wang, Y Zhang, B Ren
IJCAI-ECAI 2026, the 35th International Joint Conference on Artificial …, 2026
2026
Ultrafast local demagnetization in systems via driven Jahn-Teller distortions
M van Veenendaal
Physical Review B 113 (19), 195114, 2026
2026
Uncertainty quantification for inverse problems with application to ptychographic reconstruction
ZW Di, MJ Cherukara, T Zhou
Argonne National Laboratory (ANL), Argonne, IL (United States), 2026
2026
Unsupervised semantic segmentation in synchrotron computed tomography with self-correcting pseudo labels
A Yunker, P Kenesei, H Sharma, JS Park, A Miceli, R Kettimuthu
Machine Learning: Science and Technology, 2026
2 2026
XRF-to-Optical Field-of-View Localization with Vision Language Models
arXiv preprint arXiv:2608.18309, 2026
2026
ZenFlow: Enabling Stall-Free Offloading for LLM Training
T Lan, Y Wu, B Ma, Z Su, R Yang, T Bicer, M Tanaka, O Ruwase, D Li, ...
Proceedings of the ACM on Management of Data 4 (4 (SIGMOD), 1-28, 2026
4 2026
A Joint Variational Framework for Multimodal X-ray Ptychography and Fluorescence Reconstruction
CE Zou, E Buser, ZW Di, Y Xi
arXiv preprint arXiv:2511.02153, 2025
2025
A SWIN-based vision transformer for high-fidelity and high-speed imaging experiments at light sources
S Tang, T Bicer, K Fezzaa, S Clark
Frontiers in High Performance Computing 3, 1537080, 2025
1 2025
Accelerating Ptychography Algorithm Development with Reasoning Large Language Models
X Yin, C Shi, Y Han, Y Jiang
Microscopy and Microanalysis 31 (Supplement_1), ozaf048. 039, 2025
2025
Adapting General-Purpose Foundation Models for X-ray Ptychography in Low-Data Regimes
R Umeike, N Getty, Y Xiangyu, Y Jiang
arXiv preprint arXiv:2511.02503, 2025
1 2025
AI-DINO: Artificial Intelligence for the Dynamic Imaging of Nanoscale Objects
C Sommerfield, N Andrejevic
Bulletin of the American Physical Society, 2025
2025
AutoFocus: AI/ML-driven real-time wavefront diagnostics to autonomously align and optimize X-ray optics
L Rebuffi, R Zhang, X Shi, YC Lin, J Zhao, MY Hu, T Toellner, ...
Optics Express 33 (18), 37931-37955, 2025
3 2025
Autonomous Reduction and Analysis of 2D Diffraction and Scattering Data
AH Merritt, W Xu, O Borkiewicz, M Chu, N Schwarz, B Toby, J Weng
Structural Dynamics 12 (5_Supplement), A149-A149, 2025
2025
Bilateral Chronic Anterior Cruciate Ligament Tear or Congenital Absence of Anterior Cruciate Ligament?–A Case Report
A Sahu, H Sharma, M Asthana, A Ali, C Sharma, N Jajodia
Journal of Orthopaedic Case Reports 15 (8), 82, 2025
2025
Boosting Noise2Inverse via enhanced model selection for denoising computed tomography data
Tomography of Materials and Structures, 100075, 2025
1 2025
Catalytic entanglement transformations with noisy hardware
H Sharma, A Mokeev, J Helsen, J Borregaard
arXiv preprint arXiv:2505.05964, 2025
2025
CNN-enhanced nanostructure characterization via combined x-ray ptychography and SAXS imaging (pty-co-SAXS)
J McCourt, J Deng, B Lee, S Seifert, M Cherukara, H Sharma, M Du, ...
X-Ray Nanoimaging: Instruments and Methods VII, PC1362207, 2025
2025
Compression of Kitaev quantum spin liquid candidate Na3Co2SbO6 to megabar pressures
E Poldi, R Tartaglia, GFL Fabbris, NH Nguyen, H Park, Z Liu, ...
24th Biennial Conference of the APS Topical Group on Compression of …, 2025
2025
Crystallographic texture, structure, and stress transmission in Nugget sandstone examined with X‐ray tomography and diffraction microscopy
RC Hurley, Y Tian, MM Thakur, JS Park, P Kenesei, H Sharma, A Gupta, ...
Journal of Geophysical Research: Solid Earth 130 (7), e2025JB031690, 2025
5 2025
Dark-field X-ray microscopy with structured illumination for three-dimensional imaging
D Gürsoy, KA Yay, E Kisiel, M Wojcik, D Sheyfer, A Last, M Highland, ...
Communications Physics 8 (1), 34, 2025
14 2025
Deep learning of structural morphology imaged by scanning X-ray diffraction microscopy
A Luo, T Zhou, MV Holt, A Singer, MJ Cherukara
Scientific Reports 15 (1), 21736, 2025
3 2025
Deep learning-based spatio-temporal fusion for high-fidelity ultra-high-speed X-ray radiography
S Tang, T Bicer, T Sun, K Fezzaa, SJ Clark
Synchrotron Radiation 32 (2), 432-441, 2025
7 2025
Deep Learning-based Spatio-temporal Fusion for High-speed X-ray Radiography
Radiographic Imaging and Tomography, RW1E. 5, 2025
2025
Demonstration of an AI-driven workflow for dynamic x-ray spectroscopy
M Du, M Wolfman, C Sun, SD Kelly, MJ Cherukara
npj Computational Materials 11 (1), 320, 2025
6 2025
Direct Microstructural Observations and Atomistic Simulations on Hematite to Magnetite Reduction
V Chavan, NN Pai, A Prakash, P Raut, B Hazra, HK Mehtani, H Sharma, ...
Acta Materialia, 121269, 2025
1 2025
Done before needed: The infrastructure that made crystallography so popular for machine learning
BH Toby
Structural Dynamics 12 (5_Supplement), A161-A161, 2025
2025
DONUT: physics-aware machine learning for real-time X-ray nanodiffraction analysis
A Luo, T Zhou, M Du, MV Holt, A Singer, MJ Cherukara
npj Computational Materials 11 (1), 380, 2025
2 2025
Efficient distributed continual learning for steering experiments in real-time
T Bouvier, B Nicolae, A Costan, T Bicer, I Foster, G Antoniu
Future Generation Computer Systems 162, 107438, 2025
7 2025
Empowering electron ptychography with generative artificial intelligence and agentic workflows
Y Jiang, X Yin, C Shi, B Fein-Ashley, YT Shao, Y Han
Microscopy and Microanalysis 31 (Supplement_1), ozaf048. 1061, 2025
1 2025
Empowering x-ray science with LLMs and agentic workflow
X Yin, A Luktuke, Y Luo, J Deng, A Glowacki, Y Jiang
X-Ray Nanoimaging: Instruments and Methods VII, PC136220A, 2025
2025
Engineering reversibility of liquid-liquid phase separation in artificial proteins
Q Zhang, M Chu, D Ozgulbas, A Lavens, N Marks, M Du
APS Global Physics Summit 2025, 2025
2025
FastREI: Fast Rare Event Identification on X-ray Data with Cross-Stage Optimizations
Z Hu, J Wang, Z Zhong, W Zheng, H Sharma, JS Park, P Kenesei, A Miceli, ...
2025 IEEE International Conference on Big Data (BigData), 2169-2176, 2025
2 2025
Federated low-rank tensor estimation for multimodal image reconstruction
A Van Nguyen, D Klabjan, M Ryu, K Kim, Z Di
2025 International Joint Conference on Neural Networks (IJCNN), 1-8, 2025
1 2025
HiSin: A Sinogram-Aware Framework for Efficient High-Resolution Inpainting
arXiv preprint arXiv:2506.08809, 2025
2025
HiSin: Efficient High-Resolution Sinogram Inpainting via Resolution-Guided Progressive Inference
2025
Homomorphic data compression for real time photon correlation analysis
S Strempfer, ZW Di, K Yoshii, Y Cao, Q Zhang, EM Dufresne, ...
Optics Express 33 (5), 12059-12070, 2025
10 2025
Inpainting the Sinogram from Computed Tomography using Latent Diffusion Model and Physics
S Banerjee, E Jiaze, B Ren, T Bicer
2 2025
Intragranular evolution of slip system strength and activity in titanium using point-focused high-energy diffraction microscopy
Available at SSRN 5151306, 2025
3 2025
Inverse Design with Data-Driven Materials-Process Co-Optimization: Post-Combustion Carbon Capture As a Case Study
YS Chang, X Yin, C Gounaris
2025 AIChE Annual Meeting, 2025
2025
Kβ X-ray Emission Spectra Analysis Using Bayesian Optimization
Photon Science, 2025
4 2025
LLM-assisted workflows for x-ray ptychography at the advanced photon source
Y Jiang, X Yin, A Luktuke, Y Luo, J Deng
X-Ray Nanoimaging: Instruments and Methods VII, PC1362202, 2025
2025
MAGPIE: Multilevel-Adaptive-Guided Solver for Ptychographic Phase Retrieval
B Zhang, Q Li, ZW Di
arXiv preprint arXiv:2504.10118, 2025
2025
Materials data science ontology (mds-onto): Unifying domain knowledge in materials and applied data science
BP Rajamohan, ACH Bradley, VD Tran, JE Gordon, HW Caldwell, ...
Scientific Data 12 (1), 628, 2025
38 2025
Mic-hackathon 2024: hackathon on machine learning for electron and scanning probe microscopy
U Pratiush, A Houston, K Barakati, A Raghavan, R Bulanadi, X Yin, ...
Machine Learning: Science and Technology 6 (4), 040701, 2025
8 2025
Minimizing the number of edges in LC-equivalent graph states
H Sharma, K Goodenough, J Borregaard, J Helsen
arXiv preprint arXiv:2506.00292, 2025
3 2025
mLR: Scalable laminography reconstruction based on memoization
B Ma, V Nikitin, X Wang, T Bicer, D Li
Proceedings of the International Conference for High Performance Computing …, 2025
3 2025
Nodeology: creating graph-based agentic workflows for AI-assisted electron microscopy
X Yin, C Shi, B Fein-Ashley, YT Shao, Y Han, Y Jiang
Microscopy and Microanalysis 31 (Supplement_1), ozaf048. 1108, 2025
4 2025
Operating Robotic Laboratories with Large Language Models and Teachable Agents
A Vriza, M Prince, H Chan, T Zhou, MJ Cherukara
AI for Accelerated Materials Design-ICLR 2025, 2025
2 2025
Optimizing Paths for Adaptive Fly-Scan Microscopy: An Extended Version
arXiv preprint arXiv:2509.01869, 2025
2025
Pressure tuning of Kitaev spin liquid candidate Na3Co2SbO6
EHT Poldi, R Tartaglia, G Fabbris, N Nguyen, H Park, Z Liu, ...
Communications Physics 8 (1), 310, 2025
9 2025
Pressure tuning of Kitaev spin liquid candidate NaCoSbO
arXiv preprint arXiv:2503.20064, 2025
4 2025
Pty-chi: a PyTorch-based modern ptychographic data analysis package
M Du, H Ruth, S Henke, Y Jiang, V Nikitin, A Tripathi, J Deng, J Klug, ...
arXiv preprint arXiv:2510.20929, 2025
3 2025
Ptychographic image reconstruction from limited data via score-based diffusion models with physics-guidance
RM Cam, J Deng, R Kettimuthu, MJ Cherukara, T Bicer
2025 IEEE 35th International Workshop on Machine Learning for Signal …, 2025
4 2025
RADAR-Radio Afterglow Detection and AI-driven Response: A Federated Framework for Gravitational Wave Event Follow-Up
P Patel, A Corsi, EA Huerta, K Merfeld, V Tiki, Z Li, T Bicer, K Chard, ...
arXiv preprint arXiv:2507.14827, 2025
2025
Radio afterglow detection and ai-driven response (radar): A federated framework for gravitational-wave event follow-up
The Astrophysical Journal Supplement Series 280 (2), 71, 2025
2 2025
Recovering atomic-scale chemistry from fused multi-modal electron microscopy
R Hovden, J Schwartz, Y Jiang, ZW Di, SJ Rozeveld, H Zheng
US Patent 12,498,336, 2025
2025
Resilient execution of distributed X-ray image analysis workflows
HD Nguyen, T Bicer, B Nicolae, R Kettimuthu, EA Huerta, IT Foster
Frontiers in High Performance Computing 3, 1550855, 2025
3 2025
RESILIO: A Scalable and Composable Architecture for Tomographic Reconstruction Workflows
A Gueroudji, M Dorier, P Carns, P Patel, T Bicer, R Latham, R Ross, ...
Proceedings of the SC'25 Workshops of the International Conference for High …, 2025
1 2025
Single staged bilateral total hip replacement and its outcomes: A cross-sectional study
H Sharma, R Verma, L Kumar, A Ali, G Khurana, V Gurnani, S Mittal, ...
World Journal of Orthopedics 16 (8), 102298, 2025
2025
Single-distance nano-holotomography with coded apertures
V Nikitin, M Carlsson, R Mokso, P Cloetens, D Gürsoy
Optics Letters 50 (2), 574-577, 2025
8 2025
Sinogram Inpainting with Physics-Guided Latent Diffusion Model for Synchrotron Light Sources
2025 IEEE International Conference on Image Processing (ICIP), 2660-2665, 2025
3 2025
SinoTx: A transformer-based model for sinogram inpainting
E Jiaze, Z Liu, T Bicer, S Banerjee, R Kettimuthu, B Ren, IT Foster
Electronic Imaging 37, 1-6, 2025
3 2025
Spin-orbit coupling induced broadening of the spin crossover transition in divalent cobalt probed by x-ray emission
M van Veenendaal, EHT Poldi, D Haskel
Physical Review B 112 (15), 155137, 2025
1 2025
Stochastic Multigrid Method for Blind Ptychographic Phase Retrieval
B Zhang, J Deng, Y Jiang, ZW Di
arXiv preprint arXiv:2511.01793, 2025
2025
Stochastic Multigrid Minimization for Ptychographic Phase Retrieval
arXiv e-prints, arXiv: 2504.10118, 2025
2025
Stress and strain heterogeneity and persistence in uniaxially-and triaxially-loaded sandstone
S Bose, M Thakur, G Shahin, K Shanks, A Das, JS Park, P Kenesei, ...
ESS Open Archive 2025 (1110), 2025
2 2025
Structured Column Subset Selection for Bayesian Optimal Experimental Design
H Díaz, AK Saibaba, S Eswar, V Rao, ZW Di
arXiv preprint arXiv:2506.00336, 2025
1 2025
Structured illumination for surface-resolved grazing-incidence x-ray scattering
D Gürsoy, X Yang, D Sheyfer, M Wojcik, R Li, E Tsai
arXiv preprint arXiv:2505.04803, 2025
2025
The curious case of the unexpected neutron diffraction impurity
B Toby
Structural Dynamics 12 (2_Supplement), A61-A61, 2025
2025
The structures of mcgovernite and carlfrancisite reconsidered: static disorder or ordered defects and twinning?
C Lake, R Von Dreele
Structural Science 81 (6), 2025
2 2025
Toward a persistent event-streaming system for high-performance computing applications
M Dorier, A Gueroudji, V Hayot-Sasson, HD Nguyen, S Ockerman, ...
Frontiers in High Performance Computing 3, 2025
7 2025
Towards a Universal Model for Denoising Computed Tomography via Iterative Fine-Tuning
A Yunker, P Kenesei, A Chuang, H Sharma, JS Park, A Miceli, ...
2025 IEEE International Conference on Future Machine Learning and Data …, 2025
2025
Towards dark-field x-ray microscopy through coherent encoding
D Gürsoy, S Hruszkewycz
2025 IEEE International Conference on Image Processing (ICIP), 2151-2156, 2025
1 2025
Uncertainty-Guided Learning for Semantic Segmentation in CT using Noisy Pseudo Labels
2025 International Conference on Machine Learning and Applications (ICMLA …, 2025
2025
X-ray Nanoimaging of a Heterogeneous Structural Phase Transition in V2O3
Z Shao, A Luo, E Barazani, T Zhou, Z Cai, MV Holt, Y Kalcheim, A Singer
Nano Letters 25 (4), 1466-1472, 2025
9 2025
X-ray probes reveal 3D texture, structure, and force chains in sandstone
RC Hurley, Y Tian, JS Park, P Kenesei, H Sharma, A Gupta, K Lee
Authorea Preprints, 2025
2025
ZenFlow: Enabling stall-free offloading training via asynchronous updates
arXiv preprint arXiv:2505.12242, 2025
4 2025
3D imaging of magnetic domains in Nd2Fe14B using scanning hard X‐ray nanotomography
S Banerjee, D Gürsoy, J Deng, M Kahnt, M Kramer, M Lynn, D Haskel, ...
Journal of Synchrotron Radiation, 2024
3D reconstruction of a high-energy diffraction microscopy sample using multi-modal serial sectioning with high-precision EBSD and surface profilometry
G Sparks, SA Mason, MG Chapman, JS Park, H Sharma, P Kenesei, ...
Integrating materials and manufacturing innovation 13 (3), 773-803, 2024
14 2024
A simple solution to the Rietveld refinement recipe problem
BH Toby
Applied Crystallography 57 (1), 175-180, 2024
20 2024
A stochastic ADMM algorithm for large-scale ptychography with weighted difference of anisotropic and isotropic total variation
K Bui, Z Di
Inverse Problems 40 (5), 055006, 2024
10 2024
Accelerated laminographic image reconstruction using GPUs
B Ma, V Nikitin, D Li, T Bicer
Electronic Imaging 36, 1-6, 2024
3 2024
Active and transfer learning of high-dimensional neural network potentials for transition metals
B Varughese, S Manna, TD Loeffler, R Batra, MJ Cherukara, ...
ACS Applied Materials & Interfaces 16 (16), 20681-20692, 2024
10 2024
AI-enabled Lorentz microscopy for quantitative imaging of nanoscale magnetic spin textures
ARC McCray, T Zhou, S Kandel, A Petford-Long, MJ Cherukara, C Phatak
npj Computational Materials 10 (1), 111, 2024
4 2024
AI-NERD: Elucidation of relaxation dynamics beyond equilibrium through AI-informed X-ray photon correlation spectroscopy
JP Horwath, XM Lin, H He, Q Zhang, EM Dufresne, M Chu, ...
Nature Communications 15 (1), 5945, 2024
20 2024
Atypical Hydatid Cyst of Entire Right Femur with Pathological Fracture: Total Femur Replacement Case Report
H Sharma, L Garg, RK Verma, A Ali, L Agarwal, G Khurana, L Kumar, ...
Indian Journal of Orthopaedics 58 (10), 1499-1503, 2024
Automated defect identification in coherent diffraction imaging with smart continual learning
O Yildiz, K Raghavan, H Chan, MJ Cherukara, P Balaprakash, ...
Neural Computing and Applications 36 (35), 22335-22346, 2024
1 2024
Automating X-ray Fluorescence Mapping with Differentiable Modeling
X Yin, Z Wendy Di, O Antipova, S Chen, Y Jiang, A Glowacki
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 1017, 2024
Autonomous Multi-Modal Chemical Tomography using Bayesian Optimization
W Millsaps, J Schwartz, J Manassa, Z Wendy Di, Y Jiang, R Hovden
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 159, 2024
Chemical Electron Tomography at Lower Dose and Higher Resolution
R Hovden, J Schwartz, SH Sung, ZW Di, Y Jiang, J Manassa, J Pietryga, ...
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 890, 2024
CommBench: Micro-benchmarking hierarchical networks with multi-GPU, multi-NIC nodes
M Hidayetoglu, SG De Gonzalo, E Slaughter, Y Li, C Zimmer, T Bicer, ...
Proceedings of the 38th ACM International Conference on Supercomputing, 426-436, 2024
16 2024
Confirming the Determinants of Job Satisfaction among Secondary School Librarians of Delhi NCR
C Sharma, H Sharma
Journal of Library and Information Communication Technology 13 (1), 1-26, 2024
Dark-field x-ray microscopy with structured illumination
D Gürsoy, K Yay, E Kisiel, M Wojcik, D Sheyfer, M Highland, I Fisher, ...
Bulletin of the American Physical Society, 2024
Data-driven discovery of dynamics from time-resolved coherent scattering
N Andrejevic, T Zhou, Q Zhang, S Narayanan, MJ Cherukara, MKY Chan
npj Computational Materials 10 (1), 225, 2024
2 2024
Determining magnetic structures in GSAS-II using the Bilbao Crystallographic Server tool k-SUBGROUPSMAG
RB Von Dreele, L Elcoro
Structural Science 80 (5), 424-429, 2024
5 2024
Diaspora: Resilience-enabling services for real-time distributed workflows
B Nicolae, JM Wozniak, T Bicer, H Nguyen, P Patel, H Pan, A Gueroudji, ...
2024 IEEE 20th International Conference on e-Science (e-Science), 1-9, 2024
5 2024
Dichroic x-ray emission as a probe of orbital moments
M van Veenendaal
Physical Review B 110 (19), 2024
Dichroic K X-ray emission as a probe of orbital moments
M van Veenendaal
Physical Review Letters 110 (19), 2024
Dose and compositional dependence of irradiation-induced property change in FeCr
K Song, D Sheyfer, K Mizohata, M Zhang, W Liu, D Gürsoy, D Yang, ...
Journal of Nuclear Materials 594, 154998, 2024
14 2024
Efficient boundary-guided scanning for high-resolution X-ray ptychography
D Lin, Y Jiang, J Deng, FS Marin, ZW Di
Synchrotron Radiation 31 (1), 129-135, 2024
2 2024
Electronic angle focusing for neutron time-of-flight powder diffractometers
RB Von Dreele
Applied Crystallography 57 (5), 1588-1597, 2024
2 2024
Extending the Takagi-Taupin equations for x-ray nanobeam Bragg coherent diffraction
T Zhou, MJ Cherukara, S Kandel, M Allain, N Hua, O Shpyrko, ...
Physical Review B 110 (5), 054116, 2024
7 2024
FCDM: A Physics-Guided Bidirectional Frequency Aware Convolution and Diffusion-Based Model for Sinogram Inpainting
arXiv preprint arXiv:2409.06714, 2024
3 2024
FCDM: Sparse-view Sinogram Inpainting with Frequency Domain Convolution Enhanced Diffusion Models
E Jiaze, S Banerjee, T Bicer, G Wang, B Ren
CoRR, 2024
1 2024
FCDM: Sparse-view Sinogram Inpainting with Frequency Domain Convolution Enhanced Diffusion Models.
CoRR, 2024
1 2024
Fused Multi-Modal Electron Microscopy
J Manassa, M Shah, MG Cho, ZW Di, Y Jiang, JA Fessler, YT Shao, ...
Elemental Microscopy, 2024
Guidelines for communicating commensurate magnetic structures. A report of the International Union of Crystallography Commission on Magnetic Structures
JM Perez-Mato, BJ Campbell, VO Garlea, F Damay, G Aurelio, M Avdeev, ...
Structural Science 80 (4), 219-234, 2024
13 2024
High Performance Computing and Artificial Intelligence Enabled Materials Characterization and Experimental Automation
MJ Cherukara
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 1006, 2024
1 2024
Imaging 3D chemistry at 1 nm resolution with fused multi-modal electron tomography
J Schwartz, ZW Di, Y Jiang, J Manassa, J Pietryga, Y Qian, MG Cho, ...
Nature Communications 15 (1), 3555, 2024
36 2024
Integrating generative and physics-based models for ptychographic imaging with uncertainty quantification
C Ekmekci, T Bicer, ZW Di, J Deng, M Cetin
arXiv preprint arXiv:2412.10882, 2024
2 2024
ML-Enabled Single Image Magnetic Phase Reconstruction for Lorentz Transmission Electron Microscopy
ARC McCray, T Zhou, Y Li, S Kandel, A Petford-Long, MJ Cherukara, ...
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 504, 2024
Model and Data Management for Machine Learning (M2ML): integrating instruments, edge and HPC for accelerated machine learning
W Zheng, H Sharma, R Chard, P Kenesei, JS Park, N Schwarz, A Miceli, ...
2024 IEEE International Conference on Big Data (BigData), 4275-4282, 2024
1 2024
Neural network methods for radiation detectors and imaging
S Lin, S Ning, H Zhu, T Zhou, CL Morris, S Clayton, MJ Cherukara, ...
Frontiers in Physics 12, 1334298, 2024
21 2024
Observation of strain wave in the nematic phase of the iron pnictide Ba (Fe 1-x Cu x) 2 As 2 using dark-field x-ray microscopy
K Yay, E Kisiel, M Krogstad, D Gürsoy, S Hruszkewycz, Z Islam, I Fisher
Opportunities for retrieval and tool augmented large language models in scientific facilities
MH Prince, H Chan, A Vriza, T Zhou, VK Sastry, Y Luo, MT Dearing, ...
npj Computational Materials 10 (1), 251, 2024
52 2024
Optical control of adaptive nanoscale domain networks
M Zajac, T Zhou, T Yang, S Das, Y Cao, B Guzelturk, V Stoica, ...
Advanced Materials 36 (35), 2405294, 2024
6 2024
Optimizing coded-apertures for depth-resolved diffraction
D Gürsoy, D Sheyfer, M Wojcik, W Liu, J Tischler
arXiv preprint arXiv:2405.12813, 2024
1 2024
Phase Retrieval in Electron and X-ray Microscopy using Automatic Differentiation
T Zhou, M Cherukara, S Kandel, SO Hruszkewycz, C Phatak, MV Holt
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 227, 2024
Predicting ptychography probe positions using single-shot phase retrieval neural network
M Du, T Zhou, J Deng, DJ Ching, S Henke, MJ Cherukara
Optics express 32 (21), 36757-36780, 2024
12 2024
Pressure tuning of Kitaev spin liquid candidate NaCoSbOgoo
https://arxiv. org, 2024
Publisher Correction: AI-NERD: Elucidation of relaxation dynamics beyond equilibrium through AI-informed X-ray photon correlation spectroscopy
nature communications 15, 7867, 2024
Rapid detection of rare events from in situ X-ray diffraction data using machine learning
W Zheng, JS Park, P Kenesei, A Ali, Z Liu, I Foster, N Schwarz, ...
Applied Crystallography 57 (4), 1158-1170, 2024
7 2024
Recovering Stoichiometry via Multi-Modal Fused Electron Tomography
J Manassa, J Schwartz, J Oh, ZW Di, Y Jiang, H Zheng, JA Fessler, ...
Microscopy and Microanalysis 30 (Supplement_1), ozae044. 126, 2024
Resonant neutron scattering lengths
RB Von Dreele
Applied Crystallography 57 (4), 1154-1157, 2024
3 2024
Spontaneous Supercrystal Formation During a Strain‐Engineered Metal–Insulator Transition
OY Gorobtsov, L Miao, Z Shao, Y Tan, N Schnitzer, BH Goodge, J Ruf, ...
Advanced Materials 36 (32), 2403873, 2024
4 2024
Spontaneous Supercrystal Formation During a Strain‐Engineered Metal–Insulator Transition (Adv. Mater. 32/2024)
Advanced Materials 36 (32), 2470255, 2024
Steering a fleet: Adaptation for large-scale, workflow-based experiments
J Pruyne, V Hayot-Sasson, W Zheng, R Chard, JM Wozniak, T Bicer, ...
arXiv preprint arXiv:2403.06077, 2024
1 2024
STIR Software for Tomographic Image Reconstruction
N Efthimiou, S Mustafovic, R Brown, R Twyman Skelly, D Deidda, ...
Zenodo, 2024
Stochastic minibatch approach to the ptychographic iterative engine
A Tripathi, Z Wendy Di, Z Jiang, SM Wild
Optics Express 32 (17), 30199-30225, 2024
2 2024
Suppressing strain propagation in ultrahigh-Ni cathodes during fast charging via epitaxial entropy-assisted coating
C Zhao, C Wang, X Liu, I Hwang, T Li, X Zhou, J Diao, J Deng, Y Qin, ...
Nature Energy 9 (3), 345-356, 2024
247 2024
Three-dimensional hard X-ray ptychographic reflectometry imaging on extended mesoscopic surface structures
P Myint, A Tripathi, MJ Wojcik, J Deng, MJ Cherukara, N Schwarz, ...
APL Photonics 9 (6), 2024
7 2024
X-ray dichroism as a probe of orbital quenching and unquenching induced by optically excited Jahn-Teller modes
M van Veenendaal
Physical Review B 110 (23), 235149, 2024
X-ray nano-holotomography reconstruction with simultaneous probe retrieval
V Nikitin, M Carlsson, D Gürsoy, R Mokso, P Cloetens
Optics Express 32 (23), 41905-41924, 2024
21 2024
2023 AI Testbed Expeditions Report
V Vishwanath, M Emani, V Sastry, W Arnold, R Thakur, V Taylor, I Foster, ...
Argonne National Laboratory (ANL), Argonne, IL (United States). Argonne …, 2023
1 2023
3D magnetization reconstruction for Lorentz microscopy using differential programming
ARC McCray, M Cherukara, AK Petford-Long, C Phatak
Microscopy and Microanalysis 29 (Supplement_1), 1756-1757, 2023
3 2023
Advanced computational technologies for experiment control, data acquisition, and data analysis at the advanced photon source
J Hammonds, S Henke, PR Jemian, S Kandel, H Parraga, L Rebuffi, X Shi, ...
Synchrotron Radiation News 36 (6), 4-11, 2023
1 2023
AI-assisted automated workflow for real-time x-ray ptychography data analysis via federated resources
AV Babu, T Bicer, S Kandel, T Zhou, DJ Ching, S Henke, S Veseli, ...
Electronic Imaging 35 (11), 1-6, 2023
12 2023
AI-driven real-time optics control system to achieve aberration-free coherent wavefronts at fourth-generation synchrotron radiation and free electron laser beamlines
L Rebuffi, X Shi, R Zhang, MJ Highland, MG Frith, W Cha, RJ Harder, ...
Advances in Computational Methods for X-Ray Optics VI 12697, 97-102, 2023
1 2023
Assuring Quality in Rietveld Refinements
BH Toby
Acta Cryst 79, a165, 2023
AutoFocus: AI-driven alignment of nanofocusing X-ray mirror systems
L Rebuffi, S Kandel, X Shi, R Zhang, RJ Harder, W Cha, MJ Highland, ...
Optics Express 31 (24), 39514-39527, 2023
21 2023
Autonomous Electron Tomography Reconstruction Using Bayesian Optimization
W Millsaps, J Schwartz, ZW Di, Y Jiang, R Hovden
Microscopy and Microanalysis 29 (Supplement_1), 1915-1916, 2023
1 2023
Autonomous Electron Tomography Reconstruction with Machine Learning
Microscopy and Microanalysis 29 (5), 1650-1657, 2023
2 2023
Bayesian optimization for autoalignment of an x-ray focusing system
S Kandel, L Rebuffi, W Cha, R Harder, X Shi, M Highland, M Frith, ...
Optica Open, 2023
3 2023
CEGANN: Crystal Edge Graph Attention Neural Network for multiscale classification of materials environment
S Banik, D Dhabal, H Chan, S Manna, M Cherukara, V Molinero, ...
npj Computational Materials 9 (1), 23, 2023
63 2023
Characterization of irradiation damage using X-ray diffraction line-profile analysis
R Thomas, Ö Koç, T Ungár, G Zilahi, Z Hegedues, U Lienert, G Ribárik, ...
Zirconium in the Nuclear Industry: 20th International Symposium, 540-567, 2023
3 2023
Cover Picture: Influence of Potassium Metal‐Support Interactions on Dendrite Growth (Angew. Chem. Int. Ed. 23/2023)
P Liu, D Yen, BS Vishnugopi, VR Kankanallu, D Gürsoy, M Ge, J Watt, ...
Angewandte Chemie International Edition 62 (23), e202305585, 2023
Crystallographic Insight of Reduced Lattice Volume Expansion in Mesoporous Cu2+‐Doped TiNb2O7 Microspheres during Li+ Insertion
C Yang, D Ma, J Yang, M Manawan, T Zhao, Y Feng, J Li, Z Liu, ...
Advanced Functional Materials 33 (15), 2212854, 2023
94 2023
Data-driven discovery of dynamics from time-resolved coherent X-ray scattering
N Andrejevic, M Cherukara, M Chan, T Zhou, Q Zhang, S Narayanan
APS March Meeting Abstracts 2023, W45. 004, 2023
Deep learning at the edge enables real-time streaming ptychographic imaging
AV Babu, T Zhou, S Kandel, T Bicer, Z Liu, W Judge, DJ Ching, Y Jiang, ...
Nature Communications 14 (1), 7059, 2023
91 2023
Deep learning for improving grain mapping from Near-field high-energy diffraction microscopy
X Guo, H Sharma
ACTA CRYSTALLOGRAPHICA A-FOUNDATION AND ADVANCES 79, C451-C451, 2023
Defect identification in simulated Bragg coherent diffraction imaging by automated AI
W Judge, H Chan, S Sankaranarayanan, RJ Harder, J Cabana, ...
MRS bulletin 48 (2), 124-133, 2023
7 2023
Demonstrating cross-facility data processing at scale with Laue microdiffraction
M Prince, D Gürsoy, D Sheyfer, R Chard, B Côté, H Parraga, B Frosik, ...
Proceedings of the SC'23 Workshops of The International Conference on High …, 2023
8 2023
Demonstration of an AI-driven workflow for autonomous high-resolution scanning microscopy
S Kandel, T Zhou, AV Babu, Z Di, X Li, X Ma, M Holt, A Miceli, C Phatak, ...
Nature Communications 14 (1), 5501, 2023
68 2023
Digital autofocusing of a coded-aperture Laue diffraction microscope
D Gürsoy, D Sheyfer, M Wojcik, W Liu, JZ Tischler
Review of Scientific Instruments 94 (1), 013702, 2023
6 2023
Dose requirements for fused multi-modal electron tomography
J Manassa, J Schwartz, Y Jiang, H Zheng, JA Fessler, Z Wendy Di, ...
Microscopy and Microanalysis 29 (Supplement_1), 1968-1969, 2023
1 2023
Electronic structure of Co states in the Kitaev material candidate honeycomb cobaltate probed with x-ray dichroism
M Van Veenendaal, EHT Poldi, LSI Veiga, P Bencok, G Fabbris, ...
Physical Review B 107 (21), 214443, 2023
19 2023
Elucidation of Relaxation Dynamics in Complex Fluids Through AI-informed X-ray Photon Correlation Spectroscopy
J Horwath, XM Lin, H He, Q Zhang, E Dufresne, S Sankaranarayanan, ...
APS March Meeting Abstracts 2023, W45. 005, 2023
Entanglement distribution with minimal memory requirements using time-bin photonic qudits (vol 3, 040319, 2022)
Y Zheng, H Sharma, J Borregaard
PRX QUANTUM 4 (2), 2023
Gsas-II (general Structure and Alaysis System-Ii
B Toby, R von Dreele
US Department of Energy (DOE) Software, 31, 2023
5 2023
GSAS-II (GENERAL STRUCTURE AND ALAYSIS SYSTEM-II)
BH TOBY, RB VON DREELE
Argonne National Laboratory (ANL), Argonne, IL (United States), 2023
4 2023
Hybrid BBM92 approach for GEOQKD: lab implementation and future perspectives
BP Dirks, GC do Amaral, D Bakker, L Mazzarella, I Ferrario, S Kossen, ...
International Conference on Space Optics—ICSO 2022 12777, 883-896, 2023
Imaging framework for identifying three-dimensional magnetic structures using hard x-rays
S Banerjee, J Deng, D Gürsoy, J Strempfer
Bulletin of the American Physical Society, 2023
In situ X-ray area detector flat-field correction at an operating photon energy without flat illumination
J Weng, W Xu, KM Wiaderek, OJ Borkiewicz, J Chen, RB Von Dreele, ...
Synchrotron Radiation 30 (3), 546-554, 2023
8 2023
In situ X-ray area detector flat-field correction at an operating photon energy without flat illumination. Corrigendum
Journal of Synchrotron Radiation 30 (Pt 4), 855-855, 2023
2 2023
Influence of potassium metal‐support interactions on dendrite growth
Angewandte Chemie 135 (23), e202300943, 2023
29 2023
Kitchen-based light tomography–a DIY toolkit for advancing tomography–by and for the tomography community
E Larsson, D Gürsoy, SA Hall
Tomography of Materials and Structures 1, 100001, 2023
5 2023
Mapping 3D grain and precipitate structure during in situ mechanical testing of open-cell metal foam using micro-computed tomography and high-energy X-ray diffraction microscopy
QC Johnson, P Kenesei, S Petruzza, J Plumb, H Sharma, JS Park, ...
Materials Characterization 195, 112477, 2023
14 2023
Measuring 3d chemistry at 1 nm resolution with fused multi-modal electron tomography
J Schwartz, ZW Di, Y Jiang, MG Cho, Y Qian, J Gu, S Rozeveld, P Ercius, ...
Microscopy and Microanalysis 29 (Supplement_1), 1394-1395, 2023
1 2023
Multislice forward modeling of coherent surface scattering imaging on surface and interfacial structures
P Myint, M Chu, A Tripathi, MJ Wojcik, J Zhou, MJ Cherukara, ...
Optics Express 31 (7), 11261-11273, 2023
7 2023
Plasmonic nanorod probes’ journey inside plant cells for in vivo SERS sensing and multimodal imaging
VC Garcia, JQ Li, SJ Stephen, RA Odion, P Strobbia, L Menozzi, C Ma, ...
Nanoscale, 2023
13 2023
Reconstruction of simulated electrostatic potentials by automatic differentiation-based phase retrieval in electron microscopy imaging
CG Carr, T Zhou, M Cherukara, C Phatak, SM Haile
MRS communications 13 (5), 871-876, 2023
3 2023
Resolving intragranular stress fields in plastically deformed titanium using point-focused high-energy diffraction microscopy
W Li, H Sharma, P Kenesei, S Ravi, H Sehitoglu, A Bucsek
Journal of Materials Research 38 (1), 165-178, 2023
37 2023
Simultaneous reconstruction and uncertainty quantification for tomography
A Dasgupta, C Graziani, ZW Di
ICASSP 2023-2023 IEEE International Conference on Acoustics, Speech and …, 2023
6 2023
Systems and methods for generating phase diagrams for metastable material states
S Sankaranarayanan, TD Loeffler, H Chan, MJ CHERUKARA, ...
US Patent App. 18/138,827, 2023
4 2023
Systems and methods for hierarchical multi-objective optimization
H Chan, MJ CHERUKARA, B Narayanan, S Sankaranarayanan, SK Gray, ...
US Patent 11,663,494, 2023
The spatial wavefunction of half-integer spins
M van Veenendaal
Physica Scripta 98 (12), 125003, 2023
The T2 structure of polycrystalline cubic human insulin
DP Triandafillidis, F Karavassili, M Spiliopoulou, A Valmas, ...
Biological Crystallography 79 (5), 374-386, 2023
7 2023
Throughput optimization with a numa-aware runtime system for efficient scientific data streaming
H Jamil, J Chung, T Bicer, T Kosar, R Kettimuthu
Proceedings of the SC'23 Workshops of the International Conference on High …, 2023
3 2023
TomoSuitePY: A Pythonic Workflow for Noisy and Sparse Angle Tomography
W Judge, V De Andrade, T Bicer, F De Carlo, J Cabana, E Allen
ChemRxiv 2023 (1003), 2023
1 2023
Unsupervised classification for region of interest in X-ray ptychography
D Lin, Y Jiang, J Deng, ZW Di
Scientific Reports 13 (1), 19747, 2023
X-ray imaging across scales to understand environmental system function
KM Kemner, L Stetten, M Boyanov, EJ O'Loughlin, D Sholto-Douglas, ...
AGU23, 2023
2022 AI Testbed Expeditions Report
V Vishwanath, M Emani, V Taylor, I Foster, S Habib, ME Papka, AV Babu, ...
Argonne National Laboratory (ANL), Argonne, IL (United States), 2022
A deep generative approach to oversampling in ptychography
S Barutcu, AK Katsaggelos, D Gürsoy
arXiv preprint arXiv:2207.14392, 2022
3 2022
A lightweight, user-configurable detector ASIC digital architecture with on-chip data compression for MHz X-ray coherent diffraction imaging
S Strempfer, T Zhou, K Yoshii, M Hammer, A Babu, D Bycul, J Weizeorick, ...
Journal of Instrumentation 17 (10), P10042, 2022
12 2022
A reliable workflow for improving nanoscale X-ray fluorescence tomographic analysis on nanoparticle-treated HeLa cells
Y Luo, T Paunesku, O Antipova, Y Liu, NJ Zaluzec, Z Di, G Woloschak, ...
Metallomics 14 (9), mfac025, 2022
8 2022
A Workflow for Improving Nanoscale X-ray Fluorescence Tomographic Analysis
Microscopy and Microanalysis 28 (S1), 1326-1326, 2022
Accelerating error correction in tomographic reconstruction
S Ali, M Otten, ZW Di
Communications Materials 3 (1), 47, 2022
1 2022
Advances in Imaging Magnetic Domains in Functional Materials using Lorentz microscopy
C Phatak, ARC McCray, Y Li, T Zhou, MJ Cherukara, MG Kanatzidis, ...
Microscopy and Microanalysis, 2570-2571, 2022
Advancing AI/ML at the advanced photon source
C Benmore, T Bicer, MKY Chan, Z Di, D Gürsoy, I Hwang, N Kuklev, D Lin, ...
Synchrotron Radiation News 35 (4), 28-35, 2022
18 2022
AI-Enabled X-ray Science at the Advanced Photon Source
M Cherukara
22nd Biennial Conference of the APS Topical Group on Shock Compression of …, 2022
Automated continual learning of defect identification in coherent diffraction imaging
O Yildiz, H Chan, K Raghavan, W Judge, MJ Cherukara, P Balaprakash, ...
2022 IEEE/ACM International Workshop on Artificial Intelligence and Machine …, 2022
2 2022
AutoPhaseNN: unsupervised physics-aware deep learning of 3D nanoscale Bragg coherent diffraction imaging
Y Yao, H Chan, S Sankaranarayanan, P Balaprakash, RJ Harder, ...
npj Computational Materials 8 (1), 124, 2022
77 2022
AutoPhaseNN: unsupervised physics-aware deep learning of 3D nanoscale Bragg coherent diffraction imaging. npj Computational Materials, 8 (1): 124, June 2022
ISSN, 2022
5 2022
BraggNN: fast X-ray Bragg peak analysis using deep learning
Z Liu, H Sharma, JS Park, P Kenesei, A Miceli, J Almer, R Kettimuthu, ...
IUCrJ 9 (1), 104-113, 2022
75 2022
Carboxylic Group Rotation and Lattice Expansion in a Co2 (Pyrazine-2, 3-Dicarboxylate) 2 (4, 4′-Bipyridine) Porous Coordination Polymer Induced by CO2 Adsorption at Ambient …
S Urcia-Romero, RR Arrieta-Pérez, BH Toby, AJ Hernández-Maldonado
Crystal Growth & Design 22 (4), 2382-2391, 2022
1 2022
CEGAN: Crystal Edge Graph Attention Network for multiscale classification of materials environment
S Sankaranarayanan, S Banik, D Dhabal, H Chan, S Manna, ...
CodEx: a modular framework for joint temporal de-blurring and tomographic reconstruction
S Majee, S Aslan, D Gürsoy, CA Bouman
IEEE Transactions on Computational Imaging 8, 666-678, 2022
14 2022
Compressive ptychography using deep image and generative priors
S Barutcu, D Gürsoy, AK Katsaggelos
arXiv preprint arXiv:2205.02397, 2022
10 2022
Confined growth of DNA-assembled superlattice films
CY Zheng, Y Yao, J Deng, S Seifert, AM Wong, B Lee, CA Mirkin
ACS nano 16 (3), 4813-4822, 2022
18 2022
Crystallographic hallucinations
BH Toby
Crystal Structure Communications 78 (2), 70-71, 2022
1 2022
Deep learning the properties of inorganic perovskites
MJ Cherukara, A Mannodi-Kanakkithodi
Modelling and Simulation in Materials Science and Engineering 30 (3), 034005, 2022
11 2022
Depth-resolved Laue microdiffraction with coded apertures
Journal of Applied Crystallography 55 (5), 2022
11 2022
Determination of physically based pseudo-Voigt powder diffraction profile terms from the fundamental parameters approach
JJ Denney, GS Mattei, MH Mendenhall, JP Cline, PG Khalifah, BH Toby
Applied Crystallography 55 (2), 289-295, 2022
6 2022
Dual-shell silicate and alumina coating for long lasting and high capacity lithium ion batteries
M Lucero, TM Holstun, Y Yao, R Faase, M Wang, AT N'Diaye, DP Cann, ...
Journal of Energy Chemistry 68, 314-323, 2022
10 2022
arXiv preprint arXiv:2212.03984, 2022
4 2022
Evaluating scistream (federated scientific data streaming architecture) on fabric
C Qu, J Chung, Z Liu, T Bicer, R Kettimuthu
2022 IEEE/ACM International Workshop on Innovating the Network for Data …, 2022
2 2022
fairDMS: Rapid model training by data and model reuse
A Ali, H Sharma, R Kettimuthu, P Kenesei, D Trujillo, A Miceli, I Foster, ...
2022 IEEE International Conference on Cluster Computing (CLUSTER), 394-405, 2022
7 2022
Functional properties of Yttrium Iron Garnett thin films on graphene-coated Gd3Ga5O12 for remote epitaxial transfer
S Leontsev, PJ Shah, HS Kum, JL McChesney, FM Rodolakis, ...
Journal of Magnetism and Magnetic Materials 556, 169440, 2022
18 2022
High-Energy X-ray Diffraction Microscopy for Nuclear Forensics FY2022 Project Report
DR McLain, JD Almer, KJ DeAngeles, X Guo, KC Hepler, AJ Krzysko, ...
High-resolution ptychographic imaging enabled by high-speed multi-pass scanning
J Deng, Y Yao, Y Jiang, S Chen, TM Mooney, JA Klug, FS Marin, ...
Optics Express 30 (15), 26027-26042, 2022
16 2022
Imaging atomic-scale chemistry from fused multi-modal electron microscopy
J Schwartz, ZW Di, Y Jiang, AJ Fielitz, DH Ha, SD Perera, I El Baggari, ...
npj Computational Materials 8 (1), 16, 2022
28 2022
Imaging atomic-scale chemistry from fused multi-modal electron microscopy. npj Comput Mater 8, 16 (2022)
DOI: https://doi. org/10.1038/s41524-021-00692-5, 2022
2 2022
Influence of Crystalline Structure on Strength Anisotropy of Silica Sand
WH Imseeh, KA Alshibli, P Kenesei, H Sharma
International Workshop on Bifurcation and Degradation in Geomaterials, 87-98, 2022
2 2022
Interpretation of Ir -edge isotropic x-ray absorption spectra across the pressure-induced dimerization transition in hyperhoneycomb
M van Veenendaal, D Haskel
Physical Review B 105 (21), 214420, 2022
3 2022
Large scale caching and streaming of training data for online deep learning
J Liu, B Nicolae, D Li, JM Wozniak, T Bicer, Z Liu, I Foster
Proceedings of the 12th Workshop on AI and Scientific Computing at Scale …, 2022
11 2022
Learning in continuous action space for developing high dimensional potential energy models
S Manna, TD Loeffler, R Batra, S Banik, H Chan, B Varughese, ...
Nature communications 13 (1), 368, 2022
79 2022
Lessons Learned From my First Structures
B Toby
Acta Cryst 78, a191, 2022
Linking scientific instruments and computation: Patterns, technologies, and experiences
R Vescovi, R Chard, ND Saint, B Blaiszik, J Pruyne, T Bicer, A Lavens, ...
Patterns 3 (10), 2022
69 2022
Measuring 3D Chemistry with Fused Multi-Modal Electron Tomography
J Schwartz, J Pietryga, J Rowell, JA Fessler, S Rozeveld, Y Jiang, ZW Di, ...
Microscopy and Microanalysis 28 (S1), 2622-2624, 2022
Method to Determine the Distribution of Substituted or Intercalated Ions in Transition-Metal Dichalcogenides: FexVSe2 and Fe1–xVxSe2
M Lemon, RN Gannon, P Lu, SR Battey, SP Rudin, BH Toby, DC Johnson
Chemistry of materials 34 (19), 8528-8535, 2022
3 2022
Multi-reward reinforcement learning based bond-order potential to study strain-assisted phase transitions in phosphorene
A Koneru, R Batra, S Manna, TD Loeffler, H Chan, M Sternberg, A Avarca, ...
The Journal of Physical Chemistry Letters 13 (7), 1886-1893, 2022
29 2022
Photon-starved x-ray ptychographic imaging using spatial pyramid atrous convolution end-to-end reconstruction (ptychospacer)
Z Wu, I Kang, T Zhou, V Coykendall, B Ge, MJ Cherukara, G Barbastathis
Computational Optical Sensing and Imaging, CF1D. 6, 2022
1 2022
Physics by Michel van Veenendaal
M van Veenendaal
Physics-Inspired Unsupervised Classification for Region of Interest in X-Ray Ptychography
arXiv preprint arXiv:2206.14940, 2022
Pressure cells for in situ neutron total scattering: time and real-space resolution during deuterium absorption
K Ikeda, H Ohshita, T Otomo, K Sakaki, H Kim, Y Nakamura, A Machida, ...
Applied Crystallography 55 (6), 1631-1639, 2022
10 2022
Real-time X-ray phase-contrast imaging using SPINNet—a speckle-based phase-contrast imaging neural network
Z Qiao, X Shi, Y Yao, MJ Wojcik, L Rebuffi, MJ Cherukara, L Assoufid
Optica 9 (4), 391-398, 2022
32 2022
Scalable and accurate multi-GPU based image reconstruction of large-scale ptychography data
X Yu, V Nikitin, DJ Ching, S Aslan, D Gürsoy, T Bicer
Scientific Reports 12 (1), 1-16, 2022
37 2022
Scalable and accurate multi-GPU-based image reconstruction of large-scale ptychography data
X Yu, V Nikitin, DJ Ching, S Aslan, D Gürsoy, T Biçer
Scientific reports 12 (1), 5334, 2022
37 2022
SciStream: Architecture and toolkit for data streaming between federated science instruments
J Chung, W Zacherek, AJ Wisniewski, Z Liu, T Bicer, R Kettimuthu, I Foster
Proceedings of the 31st International Symposium on High-Performance Parallel …, 2022
26 2022
Self-absorption correction in x-ray fluorescence imaging
M Ge, X Huang, H Yan, D Gürsoy, Y Meng, J Zhang, S Ghose, W Chiu, ...
241st Electrochemical Society (ECS) Meeting, 2022
SOLAR: A Highly Optimized Data Loading Framework for Distributed Training of CNN-based Scientific Surrogates
B Sun, X Yu, C Zhang, J Tian, S Jin, K Iskra, T Zhou, T Bicer, P Beckman, ...
arXiv preprint arXiv:2211.00224, 2022
1 2022
Speeding up Diffraction Analysis using Machine Learning
H Sharma, JS Park, P Kenesei, J Almer, Z Liu, A Miceli
ACTA CRYSTALLOGRAPHICA A-FOUNDATION AND ADVANCES 78, A141-A141, 2022
Techno-Economic Optimization of an Off-Grid Hybrid Power Generator for SRM IST University, Delhi-NCR Campus. Energies 2022, 15, 7880
S Sambhi, H Sharma, P Kumar, G Fotis, V Vita, L Ekonomou
s Note: MDPI stays neu-tral with regard to jurisdictional claims in …, 2022
The APS scientific computing strategy
N Schwarz, T BRIAN
Argonne Natioonal Laboratory, Tech. Rep, 2022
6 2022
Three-dimensional imaging of grain boundaries via quantitative fluorescence x-ray tomography analysis
M Ge, X Huang, H Yan, D Gürsoy, Y Meng, J Zhang, S Ghose, WKS Chiu, ...
Communications Materials 3 (1), 1-11, 2022
23 2022
Tike
D Gürsoy, DJ Ching
Argonne National Lab.(ANL), Argonne, IL (United States), 2022
7 2022
Transfer and Active Learning of High Dimensional Neural Network Potentials for Transition Metal Clusters and Bulk
S Sankaranarayanan, B Varughese, S Manna, T Loeffler, R Batra, ...
Ultrafast X-ray spectroscopy on nonequilibrium systems
M van Veenendaal
Northern Illinois University, DeKalb, IL (United States), 2022
X-ray nano-imaging of defects in thin film catalysts via cluster analysis
A Luo, OY Gorobtsov, JN Nelson, DY Kuo, T Zhou, Z Shao, R Bouck, ...
Applied Physics Letters 121 (15), 2022
11 2022
X-ray nanodiffraction imaging reveals distinct nanoscopic dynamics of an ultrafast phase transition
Y Ahn, MJ Cherukara, Z Cai, M Bartlein, T Zhou, A DiChiara, DA Walko, ...
Proceedings of the National Academy of Sciences 119 (19), e2118597119, 2022
20 2022
2p x-ray absorption spectroscopy of 3d transition metal systems
FMF De Groot, H Elnaggar, F Frati, R Wang, MU Delgado-Jaime, ...
Journal of Electron Spectroscopy and Related Phenomena 249, 147061, 2021
130 2021
3d autoencoders for feature extraction in X-ray tomography
A Tekawade, Z Liu, P Kenesei, T Bicer, F De Carlo, R Kettimuthu, I Foster
2021 IEEE International Conference on Image Processing (ICIP), 3477-3481, 2021
10 2021
Achieving high spatial resolution in a large field-of-view using lensless x-ray imaging
Y Jiang, J Deng, Y Yao, JA Klug, S Mashrafi, C Roehrig, C Preissner, ...
Applied Physics Letters 119 (12), 2021
32 2021
Adorym: A multi-platform generic X-ray image reconstruction framework based on automatic differentiation
M Du, S Kandel, J Deng, X Huang, A Demortiere, TT Nguyen, R Tucoulou, ...
Optics express 29 (7), 10000-10035, 2021
38 2021
AD_LTEM
C Phatak, T Zhou, M Cherukara
US Department of Energy (DOE) Software, 148, 2021
AI-guided engineering of nanoscale topological materials
S Srinivasan, M Cherukara, D Eckstein, A Avarca, S Sankaranarayanan, ...
APS March Meeting Abstracts 2021, L21. 009, 2021
Artificial intelligence-guided De novo molecular design targeting COVID-19
S Srinivasan, R Batra, H Chan, G Kamath, MJ Cherukara, ...
ACS omega 6 (19), 12557-12566, 2021
45 2021
AutoPhaseNN: unsupervised physics-aware deep learning of 3D nanoscale coherent imaging
arXiv e-prints, arXiv: 2109.14053, 2021
3 2021
BLAST: bridging length/timescales via atomistic simulation toolkit: H. Chan et al.
H Chan, B Narayanan, M Cherukara, TD Loeffler, MG Sternberg, A Avarca, ...
MRS Advances 6 (2), 21-31, 2021
14 2021
Bridging data center AI systems with edge computing for actionable information retrieval
Z Liu, A Ali, P Kenesei, A Miceli, H Sharma, N Schwarz, D Trujillo, H Yoo, ...
2021 3rd Annual Workshop on Extreme-scale Experiment-in-the-Loop Computing …, 2021
43 2021
Broadband X-ray ptychography using multi-wavelength algorithm
Y Yao, Y Jiang, J Klug, Y Nashed, C Roehrig, C Preissner, F Marin, ...
Synchrotron Radiation 28 (1), 309-317, 2021
55 2021
Classification of probe quality in ptychography
Optics and Photonics for Sensing the Environment, JTu5A. 2, 2021
2 2021
Collaborative software solutions and data standards for ptychographic Imaging
J Reinhardt, D McReynolds, H Krishnan, D Shapiro, B Enders, P Jemian, ...
Acta Cryst 77, C182, 2021
Compact representations of structured BFGS matrices
JJ Brust, Z Di, S Leyffer, CG Petra
Computational Optimization and Applications 80 (1), 55-88, 2021
8 2021
Differential programming enabled functional imaging with Lorentz transmission electron microscopy
npj Computational Materials 7 (1), 141, 2021
31 2021
Distributed optimization for nonrigid nano-tomography
V Nikitin, V De Andrade, A Slyamov, BJ Gould, Y Zhang, V Sampathkumar, ...
IEEE Transactions on Computational Imaging 7, 272-287, 2021
30 2021
Electronic and structural changes in SmNiO3 perovskite under doping with hydrogen
I Zaluzhnyy, P Sprau, R Tran, Q Wang, HT Zhang, Z Zhang, N Hua, ...
APS March Meeting Abstracts 2021, X43. 003, 2021
Evolution of texture and internal stresses within polycrystalline rock salt using in situ 3D synchrotron computed tomography and 3D X-ray diffraction
A Moslehy, KA Alshibli, TJ Truster, P Kenesei, WH Imseeh, Z Jarrar, ...
Applied Crystallography 54 (5), 1379-1393, 2021
6 2021
Fast digital lossy compression for X-ray ptychographic data
P Huang, M Du, M Hammer, A Miceli, C Jacobsen
Synchrotron Radiation 28 (1), 292-300, 2021
14 2021
Fast x-ray nanotomography with sub-10 nm resolution as a powerful imaging tool for nanotechnology and energy storage applications
V De Andrade, V Nikitin, M Wojcik, A Deriy, S Bean, D Shu, T Mooney, ...
Advanced Materials, e2008653, 2021
95 2021
Hierarchical Analysis of Halo Center in Cosmology
Z Di, E Rangel, S Yoo, SM Wild
International Conference on Computational Science, 671-684, 2021
High-performance ptychographic reconstruction with federated facilities
T Bicer, X Yu, DJ Ching, R Chard, MJ Cherukara, B Nicolae, R Kettimuthu, ...
Smoky Mountains Computational Sciences and Engineering Conference, 173-189, 2021
14 2021
Improving reproducibility in synchrotron tomography using implementation-adapted filters
PS Ganguly, DM Pelt, D Gürsoy, F De Carlo, KJ Batenburg
arXiv preprint arXiv:2103.08288, 2021
2 2021
Inversion of coherent surface scattering images via deep learning network
JW Kim, MJ Cherukara, A Tripathi, Z Jiang, J Wang
Applied Physics Letters 119 (19), 2021
10 2021
Joint ptycho-tomography with deep generative priors
S Aslan, Z Liu, V Nikitin, T Bicer, S Leyffer, D Gürsoy
Machine Learning: Science and Technology 2 (4), 045017, 2021
21 2021
Learning in Continuous Action Space for Determination of High Dimensional Potential Energy Surfaces
S Sankaranarayanan, S Manna, T Loeffler, R Batra, S Banik, H Chan, ...
1 2021
Learning with delayed rewards—a case study on inverse defect design in 2D materials
S Banik, TD Loeffler, R Batra, H Singh, MJ Cherukara, ...
ACS applied materials & interfaces 13 (30), 36455-36464, 2021
31 2021
Learning with Delayed Rewards A Case Study on Inverse Defect Design in 2D Materials
33 2021
Lensless x-ray nanoimaging: revolutions and opportunities
D Gürsoy, YK Chen-Wiegart, C Jacobsen
IEEE Signal Processing Magazine 39 (1), 44-54, 2021
6 2021
Limited-angle computed tomography with deep image and physics priors
S Barutcu, S Aslan, AK Katsaggelos, D Gürsoy
Scientific Reports 11 (1), 1-12, 2021
67 2021
Low-rank tensor regression for x-ray tomography
SR Jantre, ZW Di
2021 IEEE International Conference on Image Processing (ICIP), 2833-2837, 2021
2 2021
MemXCT: design, optimization, scaling, and reproducability of x-ray tomography imaging
M Hidayetoglu, T Bicer, SG de Gonzalo, B Ren, D Gürsoy, R Kettimuthu, ...
IEEE Transactions on Parallel and Distributed Systems, 2021
21 2021
MemXCT: design, optimization, scaling, and reproducibility of x-ray tomography imaging
M Hidayetoğlu, T Biçer, SG de Gonzalo, B Ren, D Gürsoy, R Kettimuthu, ...
IEEE Transactions on Parallel and Distributed Systems 33 (9), 2014-2031, 2021
21 2021
Method development of X-ray ptychography: Towards high-resolution and high-throughput coherent imaging
Y Yao, J Deng, JA Klug, Y Jiang, M Wojcik, C Roehrig, C Preissner, Z Cai, ...
Digital Holography and Three-Dimensional Imaging, DTh4F. 4, 2021
1 2021
Multi-slice ptychography for continuous object within the depth of field
Y Jiang, J Deng, Y Yao, JA Klug, Z Cai, B Lai, S Vogt
X-Ray Nanoimaging: Instruments and Methods V 11839, 118390E, 2021
Neural Network for Coherent Diffraction Image Inversion
H Chan, M Cherukara, R Harder
US Department of Energy (DOE) Software, 142, 2021
Online data analysis and reduction: An important co-design motif for extreme-scale computers
I Foster, M Ainsworth, J Bessac, F Cappello, J Choi, S Di, Z Di, AM Gok, ...
The International Journal of High Performance Computing Applications 35 (6 …, 2021
19 2021
Pink'-beam X-ray powder diffraction profile and its use in Rietveld refinement
RB Von Dreele, SM Clarke, JPS Walsh
Applied Crystallography 54 (1), 3-6, 2021
12 2021
Proceedings of International Conference on Innovations in Information and Communication Technologies: ICI2CT 2020
L Garg, H Sharma, SB Goyal, A Singh
Springer Singapore, 2021
2 2021
Proton distribution visualization in perovskite nickelate devices utilizing nanofocused x rays
IA Zaluzhnyy, PO Sprau, R Tran, Q Wang, HT Zhang, Z Zhang, TJ Park, ...
Physical Review Materials 5 (9), 095003, 2021
15 2021
Proton distribution visualization in perovskite nickelate devices utilizing nanofocused X-rays
arXiv preprint arXiv:2108.06439, 2021
15 2021
Rapid 3D nanoscale coherent imaging via physics-aware deep learning
H Chan, YSG Nashed, S Kandel, SO Hruszkewycz, ...
Applied Physics Reviews 8 (2), 2021
56 2021
Real-time Edge Inference for Ptychographic Nanoscale Xray Imaging
A V Babu, Z Liu, T Bicer, S Veseli
Argonne National Lab.(ANL), Argonne, IL (United States), 2021
1 2021
Real-time image registration via a deep leaning approach for correlative X-ray and electron microscopy
Y Luo, N Zaluzec, M Cherukara, X Wu, S Chen
Microscopy and Microanalysis 27 (S1), 302-304, 2021
3 2021
Reconstruction with nonrigid alignment in tomography and 3D ptychography
V Nikitin, V De Andrade, D Gürsoy, F De Carlo
X-Ray Nanoimaging: Instruments and Methods V 11839, 118390H, 2021
Recovering chemistry at atomic resolution using multi-modal spectroscopy
J Schwartz, Y Jiang, ZW Di, T Ma, H Zheng, S Rozeveld, R Hovden
Microscopy and Microanalysis 27 (S1), 1226-1228, 2021
2 2021
Repeatability and sensitivity characterization of the far-field high-energy diffraction microscopy instrument at the Advanced Photon Source
Synchrotron Radiation 28 (6), 1786-1800, 2021
21 2021
Rietveld in 100 picoseconds
BH Toby
Applied Crystallography 54 (1), 1-2, 2021
Structure Refinement of the High-Temperature Triclinc Form of BiTaO4 From Neutron Powder Diffraction
P DeSanto, W Wong-Ng, Z Yang, JC Cook, BH Toby
P DeSanto, Winnie Wong-Ng, Zhi Yang, Jeremy C. Cook, B H. Toby, 2021
Theory of Ultrafast Low-To-High Spin Crossover in Divalent Iron Systems
W Baker, M Van Veenendaal
APS March Meeting Abstracts 2021, E25. 006, 2021
Theory of ultrafast photoinduced low-to-high spin crossover in divalent iron systems
W Baker, M van Veenendaal
Physical Review B 104 (1), 014407, 2021
5 2021
Three-dimensional reconstruction of integrated circuits by single-angle X-ray ptychography with machine learning
I Kang, Y Yao, J Deng, J Klug, S Vogt, S Honig, G Barbastathis
Computational Optical Sensing and Imaging, CTu6A. 4, 2021
2 2021
Titanium niobium oxide: from discovery to application in fast-charging lithium-ion batteries
KJ Griffith, Y Harada, S Egusa, RM Ribas, RS Monteiro, RB Von Dreele, ...
Chemistry of Materials 33 (1), 4-18, 2021
206 2021
Topology-aware optimizations for multi-gpu ptychographic image reconstruction
X Yu, T Bicer, R Kettimuthu, I Foster
Proceedings of the 35th ACM International Conference on Supercomputing, 354-366, 2021
16 2021
Uncertainty quantification for ptychography using normalizing flows
A Dasgupta, ZW Di
arXiv preprint arXiv:2111.00745, 2021
9 2021
Unraveling the advances of trace doping engineering for potassium ion battery anodes via tomography
Z Yu, R Li, K Cai, Y Yao, J Deng, S Lou, M Lu, Q Pan, G Yin, Z Jiang, ...
Journal of Energy Chemistry 58, 355-363, 2021
17 2021
Upscaling x-ray nanoimaging to macroscopic specimens
M Du, Z Di, D Gürsoy, RP Xian, Y Kozorovitskiy, C Jacobsen
Journal of Applied Crystallography 54 (2), 2021
34 2021
Using a modified double deep image prior for crosstalk mitigation in multislice ptychography
M Du, X Huang, C Jacobsen
Synchrotron Radiation 28 (4), 1137-1145, 2021
6 2021
(Invited) 4D Nanoscale Imaging of Corrosion through Coherent x-Ray Diffraction Imaging
MJ Cherukara, H Chan, T Loeffler, B Narayanan, S Sankaranarayanan, ...
Electrochemical Society Meeting Abstracts prime2020, 1275-1275, 2020
3D experimental measurements of evolution of force chains in natural silica sand
S Amirrahmat, WH Imseeh, KA Alshibli, P Kenesei, ZA Jarrar, H Sharma
Journal of Geotechnical and Geoenvironmental Engineering 146 (5), 04020027, 2020
16 2020
A three-dimensional thalamocortical dataset for characterizing brain heterogeneity
JA Prasad, AH Balwani, EC Johnson, JD Miano, V Sampathkumar, ...
Scientific Data 7 (1), 1-7, 2020
22 2020
A three-dimensional thalamocortical dataset for characterizing brain heterogeneity: Region of Interest Annotations (Nrrd)
J Prasad, A Balwani, E Johnson, J Miano, V Sampathkumar, VD Andrade, ...
4 2020
Active learning the potential energy landscape for water clusters from sparse training data
TD Loeffler, TK Patra, H Chan, M Cherukara, SKRS Sankaranarayanan
The Journal of Physical Chemistry C 124 (8), 4907-4916, 2020
44 2020
AI enabled in-situ nanoscale imaging
M Cherukara
International Conference on Nanostructured Materials (NANO 2020), 228, 2020
AI-enabled high-resolution scanning coherent diffraction imaging
MJ Cherukara, T Zhou, Y Nashed, P Enfedaque, A Hexemer, RJ Harder, ...
Applied Physics Letters 117 (4), 2020
166 2020
Big data staging with MPI-IO for interactive X-ray science
JM Wozniak, H Sharma, TG Armstrong, M Wilde, JD Almer, I Foster
arXiv preprint arXiv:2002.06258, 2020
26 2020
Bilevel optimization, deep learning and fractional Laplacian regularization with applications in tomography
H Antil, ZW Di, R Khatri
Inverse Problems 36 (6), 064001, 2020
91 2020
BLAST: bridging length/time scales via atomistic simulation toolkit
arXiv preprint arXiv:2002.10401, 2020
14 2020
Centroidal Voronoi tessellation based methods for optimal rain gauge location prediction
ZW Di, V Maggioni, Y Mei, M Vazquez, P Houser, M Emelianenko
Journal of Hydrology 584, 124651, 2020
20 2020
Comparison of distributed memory algorithms for X-ray wave propagation in inhomogeneous media
S Ali, M Du, MF Adams, B Smith, C Jacobsen
Optics Express 28 (20), 29590-29618, 2020
4 2020
Corrigendum to:“Relative merits and limiting factors for x-ray and electron microscopy of thick, hydrated organic materials”[Ultramicroscopy 184 (2018) 293–309]
M Du, C Jacobsen
Ultramicroscopy 216, 113013, 2020
2 2020
Cyberinfrastructure and System Software for Online Analysis of Large-Scale Data: Challenges and Design Choices
R Kettimuthu, Z Liu, T Bicer, I Foster
HANDBOOK ON BIG DATA AND MACHINE LEARNING IN THE PHYSICAL SCIENCES: Volume 2 …, 2020
1 2020
Deep learning-based low-dose tomography reconstruction with hybrid-dose measurements
Z Wu, T Bicer, Z Liu, V De Andrade, Y Zhu, IT Foster
2020 IEEE/ACM Workshop on Machine Learning in High Performance Computing …, 2020
11 2020
Deep priors for ptycho-tomography
Microscopy and Microanalysis 26 (S2), 2466-2466, 2020
1 2020
Determination of hard X-ray polarization from two-dimensional images
RB Von Dreele, W Xu
Applied Crystallography 53 (6), 1559-1561, 2020
2 2020
Dissipation and dynamics in ultrafast intersystem crossings
M Van Veenendaal
The Journal of Chemical Physics 152 (2), 2020
2 2020
Distributed optimization with tunable learned priors for robust ptycho-tomography
S Aslan, Z Liu, V Nikitin, T Bicer, S Leyffer, D Gursoy
arXiv preprint arXiv:2009.09498, 2020
4 2020
Evaluation of modified uniformly redundant arrays as structured illuminations for ptychography
DJ Ching, S Aslan, V Nikitin, MJ Wojcik, D Gürsoy
arXiv preprint arXiv:2004.01766, 2020
2 2020
Fast tomographic alignment for joint ptychography and tomography
AM Slyamov, V Nikitin, D Gürsoy, R Mokso, JW Andreasen
arXiv preprint arXiv:2002.00753, 2020
Ferroelectric domain wall motion in freestanding single‐crystal complex oxide thin film
SR Bakaul, J Kim, S Hong, MJ Cherukara, T Zhou, L Stan, CR Serrao, ...
Advanced Materials 32 (4), 1907036, 2020
56 2020
GPU-based static data-flow analysis for fast and scalable android app vetting
X Yu, F Wei, X Ou, M Becchi, T Bicer, D Yao
2020 IEEE International Parallel and Distributed Processing Symposium (IPDPS …, 2020
18 2020
High-energy coherent x-ray diffraction microscopy of polycrystal grains: Steps toward a multiscale approach
S Maddali, JS Park, H Sharma, S Shastri, P Kenesei, J Almer, R Harder, ...
Physical Review Applied 14 (2), 024085, 2020
20 2020
In situ high-temperature X-ray diffraction study of Sc-doped titanium oxide nanocrystallites
VY Zenou, F Bertolotti, A Guagliardi, BH Toby, RB Von Dreele, ...
Applied Crystallography 53 (6), 1452-1461, 2020
3 2020
Influence of crystal structure on constitutive anisotropy of silica sand at particle-scale
WH Imseeh, KA Alshibli, A Moslehy, P Kenesei, H Sharma
Computers and Geotechnics 126, 103718, 2020
32 2020
Lanthanide-binding tags for 3D x-ray imaging of proteins in cells at nanoscale resolution
T Victor, K O'Toole, LM Easthon, M Ge, RJ Smith, X Huang, H Yan, ...
Journal of the American Chemical Society, 2020
60 2020
Leveraging Network Programmability and In-network Computing for Streaming Analysis of Huge Data (White Paper)
J Chung, Z Liu, T Bicer, R Kettimuthu, I Foster
Machine learning enabled autonomous microstructural characterization in 3D samples
H Chan, M Cherukara, TD Loeffler, B Narayanan, ...
NPJ Computational Materials 6 (1), 1, 2020
97 2020
Machine learning technique to identify grains in polycrystalline materials samples
S Sankaranarayanan, MJ CHERUKARA, B Narayanan, H Chan
US Patent 10,839,195, 2020
Multigrid Optimization for Large-Scale Ptychographic Phase Retrieval
SW Fung, ZW Di
SIAM Journal on Imaging Sciences 13 (1), 214-233, 2020
26 2020
Multimodal x-ray nanotomography
D Gürsoy, C Jacobsen
MRS Bulletin 45 (4), 272-276, 2020
9 2020
Nanoscale imaging and control of volatile and non-volatile resistive switching in VO2
AG Shabalin, J Valle, N Hua, MJ Cherukara, MV Holt, IK Schuller, ...
Small 16 (50), 2020
66 2020
Nanoscale Imaging and Control of Volatile and Non‐Volatile Resistive Switching in VO2
AG Shabalin, J Del Valle, N Hua, MJ Cherukara, MV Holt, IK Schuller, ...
Small 16 (50), 2005439, 2020
69 2020
Near, far, wherever you are: simulations on the dose efficiency of holographic and ptychographic coherent imaging
M Du, D Gürsoy, C Jacobsen
Journal of Applied Crystallography 53 (3), 2020
18 2020
Perovskite neural trees
HT Zhang, TJ Park, IA Zaluzhnyy, Q Wang, SN Wadekar, S Manna, ...
Nature communications 11 (1), 2245, 2020
79 2020
Petascale XCT: 3D image reconstruction with hierarchical communications on multi-GPU nodes
M Hidayetoglu, T Bicer, SG de Gonzalo, B Ren, V De Andrade, D Gürsoy, ...
SC20: International Conference for High Performance Computing, Networking …, 2020
44 2020
Powder Diffraction Crystallography: 98 Years as Plan B?
BH Toby
Argonne National Laboratory (ANL), 2020
Predicting Execution Times for Disk-based and In-Situ Parallel Data Analytics (Final Technical Report)
G Zhu, G Agrawal, P Sadayappan, V Morozov, P Balaprakash, ...
The Ohio State Univ., Columbus, OH (United States), 2020
Real-time 3D nanoscale coherent imaging via physics-aware deep learning
H Chan, YSG Nashed, S Kandel, S Hruszkewycz, S Sankaranarayanan, ...
arXiv preprint arXiv:2006.09441, 2020
8 2020
Relative merits and limiting factors for x-ray and electron microscopy of thick, hydrated organic materials (2020 revised version)
M Du, C Jacobsen
Free radical biology & medicine., 2020
Relative merits and limiting factors for x-ray and electron microscopy of thick, hydrated organic materials (vol 184, pg 293, 2018)
M Du, C Jacobsen
ULTRAMICROSCOPY 216, 2020
Rietveld refinement for macromolecular powder diffraction
M Spiliopoulou, DP Triandafillidis, A Valmas, C Kosinas, AN Fitch, ...
Crystal Growth & Design 20 (12), 8101-8123, 2020
21 2020
Screening of therapeutic agents for COVID-19 using machine learning and ensemble docking studies
R Batra, H Chan, G Kamath, R Ramprasad, MJ Cherukara, ...
The journal of physical chemistry letters 11 (17), 7058-7065, 2020
113 2020
Simultaneous 3D x-ray ptycho-tomography with gradient descent
S Barutcu, P Ruiz, F Schiffers, S Aslan, D Gürsoy, O Cossairt, ...
2020 IEEE International Conference on Image Processing (ICIP), 96-100, 2020
6 2020
Systems and methods for designing new materials for superlubricity
B Narayanan, S Sankaranarayanan, AV Sumant, MJ CHERUKARA, ...
US Patent App. 16/036,039, 2020
5 2020
Three dimensions, two microscopes, one code: Automatic differentiation for x-ray nanotomography beyond the depth of focus limit
M Du, YSG Nashed, S Kandel, D Gürsoy, C Jacobsen
Science Advances 6 (13), eaay3700, 2020
52 2020
TomoGAN: low-dose synchrotron x-ray tomography with generative adversarial networks: discussion
Z Liu, T Bicer, R Kettimuthu, D Gursoy, F De Carlo, I Foster
Journal of the Optical Society of America A 37 (3), 422-434, 2020
171 2020
Tomographic Reconstruction for Synchrotron Tomography
DY Parkinson, D Gursoy, DM Pelt, S Venkatakrishnan, R Archibald, ...
1 2020
Tomographic reconstruction of dynamic features with streaming sliding subsets
T Bicer, V Nikitin, S Aslan, D Gürsoy, R Kettimuthu, IT Foster
2020 IEEE/ACM 2nd Annual Workshop on Extreme-scale Experiment-in-the-Loop …, 2020
6 2020
Translating a Material Discovery into a Commercial Product in the Modern Lithium-ion Battery Market
Chemistry of Materials 33 (1), 2020
Trilateration-Based Multilevel Method for Minimizing the Lennard-Jones Potential
J George, Z Di
International Conference on Computational Science, 163-175, 2020
Unusual breathing behavior of optically excited barium titanate nanocrystals
J Diao, M Cherukara, R Harder, X Huang, F Zhang, B Chen, A Ulvestad, ...
Crystals 10 (5), 365, 2020
4 2020
3.3. Powder diffraction peak profiles
RB Von Dreele
International Tables for Crystallography, Volume H: Powder Diffraction, 263, 2019
8 2019
4.7. Rietveld refinement
BH Toby
International Tables for Crystallography, Volume H: Powder Diffraction, 465, 2019
18 2019
Adventures in Symmetry with GSAS-II
BH Toby
ACTA CRYSTALLOGRAPHICA A-FOUNDATION AND ADVANCES 75, A342-A342, 2019
Calibrating sensing drift in tomographic inversion
X Huang, SM Wild, ZW Di
2019 IEEE International conference on image processing (ICIP), 1267-1271, 2019
7 2019
Data compression for optimization of a molecular dynamics system: preserving basins of attraction
M Retzlaff, T Munson, Z Di
International Conference on Computational Science, 457-470, 2019
1 2019
Deep learning accelerated light source experiments
2019 IEEE/ACM Third Workshop on Deep Learning on Supercomputers (DLS), 20-28, 2019
31 2019
Estimating observed structure factors without a structure
BH Toby
International Union of Crystallography, 2019
3 2019
Future Conference: 5-9 August 2019
T Fawcett, J Anzelmo, L Brehm, D Broton, S Misture, C Murray, C Noyan, ...
History
BH Toby
10 2019
Improved calibration of area detectors using multiple placements
C Horn, KM Ginell, RB Von Dreele, AA Yakovenko, BH Toby
Synchrotron Radiation 26 (6), 1924-1928, 2019
11 2019
Joint ptycho-tomography reconstruction through alternating direction method of multipliers
S Aslan, V Nikitin, DJ Ching, T Bicer, S Leyffer, D Gürsoy
Optics Express 27 (6), 9128-9143, 2019
43 2019
Library services to persons with visual impairment
S Vishwakarma, H Sharma, J Vishwadhiyalaya
International Journal of Library Information Network 4 (2), 16-26, 2019
7 2019
Magnetic dichroism in the Kondo insulator
WT Fuhrman, JC Leiner, JW Freeland, M Van Veenendaal, ...
Physical Review B 99 (2), 020401, 2019
23 2019
Mapping three-dimensional dissolution rates of calcite microcrystals: Effects of surface curvature and dissolved metal ions
K Yuan, V Starchenko, SS Lee, V De Andrade, D Gürsoy, NC Sturchio, ...
ACS Earth and Space Chemistry 3 (5), 833-843, 2019
60 2019
Materials for learning use of GSAS-II
KM Ginell, C Horn, RB Von Dreele, BH Toby
Powder Diffraction 34 (2), 184-188, 2019
43 2019
MemXCT: Memory-centric x-ray CT reconstruction with massive parallelization
M Hidayetoğlu, T Biçer, SG De Gonzalo, B Ren, D Gürsoy, R Kettimuthu, ...
Proceedings of the International Conference for High Performance Computing …, 2019
53 2019
Nanoporous gold: a hierarchical and multiscale 3D test pattern for characterizing x-ray nano-tomography systems
E Larsson, D Gürsoy, F De Carlo, E Lilleodden, M Storm, F Wilde, K Hu, ...
Journal of Synchrotron Radiation 26 (1), 2019
26 2019
Optimization-based simultaneous alignment and reconstruction in multi-element tomography
ZW Di, S Chen, D Gürsoy, T Paunescu, S Leyffer, SM Wild, S Vogt
Optics Letters 44 (17), 4331-4334, 2019
16 2019
Peak profiles for X-ray energy-dispersive experiments
RB Von Dreele
Peak-displacement effects
RB Von Dreele
Photoemission study on a special type of multiferroics: GaV4S8 & GeV4S8
A Singh, JH Li, YF Liao, HY Huang, YY Chu, J Chang, KD Tsuei, L Zhang, ...
APS March Meeting Abstracts 2019, C06. 003, 2019
Photon-limited ptychography of 3D objects via Bayesian reconstruction
V Nikitin, S Aslan, Y Yao, T Biçer, S Leyffer, R Mokso, D Gürsoy
OSA Continuum 2 (10), 2948-2968, 2019
33 2019
Protein refinement with GSAS-II
R Von Dreele
Powder Diffraction 34 (S1), S32-S35, 2019
20 2019
Simultaneous sensing error recovery and tomographic inversion using an optimization-based approach
AP Austin, ZW Di, S Leyffer, SM Wild
SIAM Journal on Scientific Computing 41 (3), B497-B521, 2019
12 2019
Sinogram image completion for limited angle tomography with generative adversarial networks
S Yoo, X Yang, M Wolfman, D Gürsoy, AK Katsaggelos
2019 IEEE International Conference on Image Processing (ICIP), 1252-1256, 2019
28 2019
Structural investigation of the “tripled-tetragonal-tungsten-bronze” phases Sr2M10− xO27− y (M= Nb, Ta)
JB Felder, W Wong-Ng, RA Qabbani, RS Roth, BH Toby, JY Chan
Polyhedron 170, 359-363, 2019
9 2019
The mechanism of Rietveld fitting
BH Toby
The order in which to introduce parameters in a fit
BH Toby
Time-coded aperture for x-ray imaging
D Ching, S Aslan, V Nikitin, D Gürsoy
Optics Letters 44 (11), 2803-2806, 2019
11 2019
X-ray characterization of the micromechanical response ahead of a propagating small fatigue crack in a Ni-based superalloy
DP Naragani, PA Shade, P Kenesei, H Sharma, MD Sangid
Acta Materialia 179, 342-359, 2019
65 2019
3D reconstruction of magnetization from dichroic soft x-ray transmission tomography
A Hierro-Rodriguez, D Gürsoy, C Phatak, C Quirós, A Sorrentino, ...
Journal of Synchrotron Radiation 25 (4), 2018
42 2018
A pipeline for distributed segmentation of teravoxel tomography datasets
M Tondravi, W Scullin, M Du, R Vescovi, V De Andrade, C Jacobsen, ...
Microscopy and Microanalysis 24 (S2), 166-167, 2018
A scripting interface for GSAS-II
JH O'Donnell, RB Von Dreele, MKY Chan, BH Toby
Applied Crystallography 51 (4), 1244-1250, 2018
47 2018
An automated pipeline for the collection, transfer, and processing of large-scale tomography data
M Du, R Vescovi, R Chard, N Kasthuri, C Jacobsen, E Dyer, D Gürsoy
Optics and the Brain, BF4C. 2, 2018
3 2018
Automated correlative segmentation of large transmission x-ray microscopy (TXM) tomograms using deep learning
CS Kaira, X Yang, V De Andrade, F De Carlo, W Scullin, D Gürsoy, ...
Materials Characterization 142, 203-210, 2018
47 2018
Deterministic and Robust Room-temperature Exchange Coupling in Monodomain Multiferroic BiFeO3 Heterostructures
B Davidson, W Saenrang, F Maccherozzi, JPP Podkaminer, J Irwin, ...
APS March Meeting Abstracts 2018, S09. 006, 2018
Deterministic and Robust Room–temperature Exchange Coupling in Monodomain Multiferroic BiFeO3 Heterostructures
Bulletin of the American Physical Society 63, 2018
Developments of x-ray fluorescence tomography at 2-ID-E at APS for studies of composite samples
O Antipova, K Kemner, C Roehrig, S Vogt, LX Li, D Gürsoy
Microscopy and Microanalysis 24 (S2), 520-521, 2018
3 2018
Diamagnetic Sm in the topological Kondo insulator SmB
WT Fuhrman, JC Leiner, JW Freeland, M van Veenendaal, ...
arXiv preprint arXiv:1804.06853, 2018
2 2018
Erratum: Origin of strong dispersion in Hubbard insulators [Phys. Rev. B 92, 075119 (2015)]
Y Wang, K Wohlfeld, B Moritz, CJ Jia, M van Veenendaal, K Wu, CC Chen, ...
Physical Review B 97 (19), 199903, 2018
2 2018
Expressways from Scientific Instrument to Supercomputer: A Prototype Demonstration
J Chung, Z Liu, T Bicer, R Kettimuthu, L Winkler, D Katramatos, NSV Rao, ...
Graphphi: efficient parallel graph processing on emerging throughput-oriented architectures
Z Peng, A Powell, B Wu, T Bicer, B Ren
Proceedings of the 27th International Conference on Parallel Architectures …, 2018
30 2018
High-energy x-ray diffraction microscopy study of deformation microstructures in neutron-irradiated polycrystalline Fe-9% Cr
X Zhang, M Li, JS Park, P Kenesei, H Sharma, J Almer
Journal of Nuclear Materials 508, 556-566, 2018
15 2018
High-speed fly-scan volumetric imaging
D Gürsoy
Microscopy and Microanalysis 24 (S1), 498-499, 2018
1 2018
Imaging of 3D morphological evolution of nanoporous silicon anode in lithium ion battery by x-ray nano-tomography
C Zhao, T Wada, V De Andrade, D Gürsoy, H Kato, YK Chen-Wiegart
Nano Energy 52, 381-390, 2018
172 2018
In situ, 3D characterization of the deformation mechanics of a superelastic NiTi shape memory alloy single crystal under multiscale constraint
HM Paranjape, PP Paul, B Amin-Ahmadi, H Sharma, D Dale, JYP Ko, ...
Acta Materialia 144, 748-757, 2018
49 2018
Low-dose x-ray tomography through a deep convolutional neural network
X Yang, V De Andrade, W Scullin, EL Dyer, N Kasthuri, F De Carlo, ...
Scientific Reports 8 (1), 2575, 2018
121 2018
Micro and nanotomographic investigations of microbial and pore structure within opaque soil aggregates
KM Kemner, S O'Brien, MD Whiteside, D Sholto-Douglas, O Antipova, ...
2018 ESA Annual Meeting (August 5--10), 2018
Microstructure analysis of bismuth absorbers for transition-edge sensor X-ray microcalorimeters
D Yan, R Divan, LM Gades, P Kenesei, TJ Madden, A Miceli, JS Park, ...
Journal of Low Temperature Physics 193 (3), 225-230, 2018
12 2018
Origin of strong dispersion in Hubbard insulators (vol 92, 075119, 2015)
PHYSICAL REVIEW B 97 (19), 2018
Photoinduced nonequilibrium dynamics in charge ordered materials
L Zhu, TF Seman, M Van Veenendaal, KH Ahn
Journal of Applied Physics 123 (11), 2018
3 2018
Role of heat treatment and build orientation in the microstructure sensitive deformation characteristics of IN718 produced via SLM additive manufacturing
MD Sangid, TA Book, D Naragani, J Rotella, P Ravi, A Finch, P Kenesei, ...
Additive Manufacturing 22, 479-496, 2018
167 2018
Rotation-as-fast-axis scanning-probe x-ray tomography: the importance of angular diversity for fly-scan modes
DJ Ching, M Hidayetoğlu, T Biçer, D Gürsoy
Applied Optics 57 (30), 8780-8789, 2018
13 2018
Time-dependent nonequilibrium soft x-ray response during a spin crossover
M van Veenendaal
Physical Review B 97 (12), 125108, 2018
4 2018
TomoBank: a tomographic data repository for computational x-ray science
F De Carlo, D Gürsoy, DJ Ching, KJ Batenburg, W Ludwig, L Mancini, ...
Measurement Science and Technology 29 (3), 034004, 2018
133 2018
Tomosaic: efficient acquisition and reconstruction of teravoxel tomography data using limited-size synchrotron x-ray beams
R Vescovi, M Du, V Andrade, W Scullin, D Gürsoy, C Jacobsen
Journal of Synchrotron Radiation 25 (5), 2018
61 2018
Tuning magnetic coercivity with external pressure in iron-rhenium based ferrimagnetic double perovskites
CA Escanhoela Jr, G Fabbris, F Sun, C Park, J Gopalakrishnan, ...
Physical Review B 98 (5), 054402, 2018
14 2018
X-ray tomography of extended objects: a comparison of data acquisition approaches
M Du, R Vescovi, K Fezzaa, C Jacobsen, D Gürsoy
Journal of the Optical Society of America A 35 (11), 1871-1879, 2018
23 2018
Xi-cam: a versatile interface for data visualization and analysis
RJ Pandolfi, DB Allan, E Arenholz, L Barroso-Luque, SI Campbell, ...
Journal of Synchrotron Radiation 25 (4), 1261-1270, 2018
160 2018
A convolutional neural network approach to calibrating the rotation axis for x-ray computed tomography
X Yang, F De Carlo, C Phatak, D Gürsoy
Journal of Synchrotron Radiation 24 (2), 469-475, 2017
68 2017
Accelerating GPU accelerators through neural algorithmic transformation
A Yazdanbakhsh, J Park, H Sharma, P Lotfi-Kamran, H Esmaeilzadeh
Advances in GPU Research and Practice, 417-448, 2017
Argonne/Oak Ridge National School on Neutron and X-ray Scattering in its 19th Year
BH Toby
Synchrotron Radiation News 30 (6), 34-34, 2017
Basic Energy Sciences Exascale Requirements Review. An Office of Science review sponsored jointly by Advanced Scientific Computing Research and Basic Energy Sciences, November …
T Windus, M Banda, T Devereaux, JC White, K Antypas, R Coffey, E Dart, ...
US Department of Energy, Washington, DC (United States). Advanced Scientific …, 2017
8 2017
Computing just what you need: Online data analysis and reduction at extreme scales
I Foster, M Ainsworth, B Allen, J Bessac, F Cappello, JY Choi, ...
European conference on parallel processing, 3-19, 2017
115 2017
Direct coupling of tomography and ptychography
D Gürsoy
Optics Letters 42 (16), 3169-3172, 2017
45 2017
Eliminating the non-Gaussian spectral response of X-ray absorbers for transition-edge sensors
Applied Physics Letters 111 (19), 2017
50 2017
Evaluation of the XTM setup at the P05 Imaging Beamline at PETRA III using a sample of nanoporous gold
E Larsson, M Ogurreck, F Wilde, M Ziehmer, K Hu, D Gursoy, F de Carlo, ...
24th International Congress on X-ray Optics and Microanalysis, 2017
Grain Structure, Grain-averaged Lattice Strains, and Macro-scale Strain Data for Superelastic Nickel-Titanium Shape Memory Alloy Polycrystal Loaded in Tension
HM Paranjapea, PP Paulb, H Sharmac, P Keneseic, JS Parkc, ...
Materials Data Facility, 2017
Influences of granular constraints and surface effects on the heterogeneity of elastic, superelastic, and plastic responses of polycrystalline shape memory alloys
HM Paranjape, PP Paul, H Sharma, P Kenesei, JS Park, TW Duerig, ...
Journal of the Mechanics and Physics of Solids 102, 46-66, 2017
57 2017
Integrated dynamic 3D imaging of microbial processes and communities in rhizosphere environments: The Argonne Small Worlds Project
KM Kemner, M Hereld, N Scherer, A Selewa, X Wang, I Gdor, ...
Microscopy and Microanalysis 23 (S1), 340-341, 2017
2 2017
Investigation of fatigue crack initiation from a non-metallic inclusion via high energy x-ray diffraction microscopy
D Naragani, MD Sangid, PA Shade, JC Schuren, H Sharma, JS Park, ...
Acta Materialia 137, 71-84, 2017
159 2017
Joint reconstruction of x-ray fluorescence and transmission tomography
ZW Di, S Chen, YP Hong, C Jacobsen, S Leyffer, SM Wild
Optics express 25 (12), 13107-13124, 2017
31 2017
Photoinduced Nonequilibrium Dynamics in Charge Density Wave Materials
L Zhu, KH Ahn, TF Seman, M Veenendaal
Bulletin of the American Physical Society 62, 2017
Pressure tuning of bond-directional exchange interactions and magnetic frustration in the hyperhoneycomb iridate
LSI Veiga, M Etter, K Glazyrin, F Sun, CA Escanhoela Jr, G Fabbris, ...
Physical Review B 96 (14), 140402, 2017
78 2017
Python in the NERSC exascale science applications program for data
Z Ronaghi, R Thomas, J Deslippe, S Bailey, D Gursoy, T Kisner, ...
Proceedings of the 7th Workshop on Python for High-Performance and …, 2017
13 2017
Quantifying mesoscale neuroanatomy using x-ray microtomography
EL Dyer, WG Roncal, JA Prasad, HL Fernandes, D Gürsoy, V De Andrade, ...
eNeuro 4 (5), 2017
93 2017
Rapid alignment of nanotomography data using joint iterative reconstruction and reprojection
D Gürsoy, YP Hong, K He, K Hujsak, S Yoo, S Chen, Y Li, M Ge, LM Miller, ...
Scientific Reports 7 (1), 11818, 2017
93 2017
Real-time data analysis and autonomous steering of synchrotron light source experiments
T Bicer, D Gürsoy, R Kettimuthu, IT Foster, B Ren, V De Andrede, ...
e-Science, 59-68, 2017
51 2017
Simulations of Photo-induced Nonequilibrium Dynamics in Charge Density Wave Materials
L Zhu, TF Seman, MV Veenendaal, K Ahn
APS March Meeting Abstracts 2017, P20. 010, 2017
Stochastic and deterministic crystal structure solution methods in GSAS-II: Monte Carlo/simulated annealing versus charge flipping
R Von Dreele
Crystals 7 (9), 264, 2017
5 2017
Synchrotron-based micro and nanotomographic investigations of soil aggregate microbial and pore structure
AGU Fall Meeting Abstracts 2017, B21J-04, 2017
1 2017
The nanoporous gold data set
E Larsson, M Storm, F Wilde, M Ziehmer, K Hu, D Gursoy, E Lilleodden, ...
Argonne National Laboratory (ANL), Argonne, IL (United States); Argonne …, 2017
1 2017
Trace: a high-throughput tomographic reconstruction engine for large-scale datasets
T Bicer, D Gürsoy, V De Andrade, R Kettimuthu, W Scullin, F De Carlo, ...
Advanced Structural and Chemical Imaging 3 (1), 6, 2017
52 2017
Ultrafast intersystem crossings in Fe-Co Prussian blue analogues
M van Veenendaal
Scientific reports 7 (1), 6672, 2017
22 2017
Wavefront reconstruction in 3D x-ray microscopy
CJ Jacobsen, V de Andrade, J Deng, M Du, D Gürsoy, YS Nashed, ...
Digital Holography and Three-Dimensional Imaging, W2A. 12, 2017
XDesign: an open-source software package for designing x-ray imaging phantoms and experiments
DJ Ching, D Gürsoy
Journal of Synchrotron Radiation 24 (2), 537-544, 2017
40 2017
3D Study of Neutron Irradiation Effects on Tensile Deformation in Fe-based Alloys using High Energy Synchrotron X-rays
X Zhang, C Xu, JS Park, H Sharma, P Kenesei, J Almer, M Li
A brief geometric derivation of some fundamental physics
M van Veenendaal
arXiv preprint arXiv:1606.08484, 2016
A new transmission x-ray microscope for in-situ nano-tomography at the APS
V De Andrade, A Deriy, M Wojcik, D Gürsoy, D Shu, T Mooney, ...
SPIE Optical Engineering+Applications, 99670H-99670H-1, 2016
5 2016
Accelerating science with the NERSC burst buffer early user program
W Bhimji, D Bard, M Romanus, D Paul, A Ovsyannikov, B Friesen, ...
Cray User Group Conference, 2016
89 2016
Characterization of irradiated metallic fuels using synchrotron radiation and electron microscopy
M Okuniewski, A Aitkaliyeva, J Harp, K Wright, B Miller, R Seibert, ...
ABSTRACTS OF PAPERS OF THE AMERICAN CHEMICAL SOCIETY 252, 2016
EEG complexity and frequency in chronic residual schizophrenia.
O TAN, S Aydin, G HIZLI SAYAR, D GÜRSOY
Anatolian Journal of Psychiatry/Anadolu Psikiyatri Dergisi 17 (5), 385, 2016
10 2016
Evolution of electronic structure across the rare-earth RNiO3 series
JW Freeland, M Van Veenendaal, J Chakhalian
Journal of Electron Spectroscopy and Related Phenomena 208, 56-62, 2016
92 2016
From sample to knowledge: Towards an integrated approach for neuroscience discovery
WG Roncal, EL Dyer, D Gürsoy, K Kording, N Kasthuri
arXiv preprint arXiv:1604.03199, 2016
Integration of TomoPy and the ASTRA toolbox for advanced processing and reconstruction of tomographic synchrotron data
DM Pelt, D Gürsoy, WJ Palenstijn, J Sijbers, F De Carlo, KJ Batenburg
Journal of Synchrotron Radiation 23 (3), 842-849, 2016
158 2016
Joint reconstruction of absorption and refractive properties in propagation-based x-ray phase-contrast tomography via a non-linear image reconstruction algorithm
Y Chen, K Wang, D Gursoy, C Soriano, F De Carlo, MA Anastasio
Medical Imaging 2016: Physics of Medical Imaging 9783, 1459-1466, 2016
1 2016
Learning from scanning transmission electron microscopy to enhance transmission x-ray microscopy
X Yang, D Gürsoy, C Phatak, V De Andrade, EB Gulsoy, F De Carlo
Microscopy and Microanalysis 22 (S3), 240-241, 2016
2 2016
Midas, microstructural imaging using diffraction analysis software
H Sharma, J Almer, JS Park, P Kenesei, M Wilde, J Wozniak
URL: https://www1. aps. anl. gov/science/scientific-software/midas, 2016
8 2016
Nanoscale 3D imaging at the Advanced Photon Source
V De Andrade, A Deriy, MJ Wojcik, D Gürsoy, D Shu, K Fezzaa, ...
SPIE Newsroom, 2-4, 2016
74 2016
Optimization of tomographic reconstruction workflows on geographically distributed resources
T Bicer, D Gürsoy, R Kettimuthu, F De Carlo, IT Foster
Journal of Synchrotron Radiation 23 (4), 997-1005, 2016
20 2016
Photoinduced ultrafast charge-order melting: Charge-order inversion and nonthermal effects
M van Veenendaal
Physical Review B 94 (11), 115101, 2016
5 2016
Preferential Nucleation during Polymorphic Transformations
H Sharma, J Sietsma, SE Offerman
Scientific Reports, 7, 2016
18 2016
Pressure-Induced Confined Metal from the Mott Insulator
Y Ding, L Yang, CC Chen, HS Kim, MJ Han, W Luo, Z Feng, M Upton, ...
Physical review letters 116 (21), 216402, 2016
57 2016
Single step x-ray phase imaging
M Das, D Gürsoy
US Patent 9,237,876, 2016
11 2016
Solving crystal structures with GSAS-II
RB Von Dreele
ACTA CRYSTALLOGRAPHICA A-FOUNDATION AND ADVANCES 72, S8-S8, 2016
2 2016
The S= 1/2 J1-J2 Heisenberg Model on the Triangular Lattice
T Seman, CC Chen, R Singh, M van Veenendaal
APS March Meeting Abstracts 2016, B5. 013, 2016
Time-resolved x-ray tomography of gasoline direct injection sprays
DJ Duke, AB Swantek, NM Sovis, FZ Tilocco, CF Powell, AL Kastengren, ...
SAE International Journal of Engines 9 (1), 143-153, 2016
56 2016
Using nonequilibrium dynamics to probe competing orders in a Mott-Peierls system
Y Wang, B Moritz, CC Chen, CJ Jia, M van Veenendaal, TP Devereaux
Physical Review Letters 116 (8), 086401, 2016
27 2016
: An inhomogeneous Hubbard system
S Chikara, D Haskel, JH Sim, HS Kim, CC Chen, G Fabbris, LSI Veiga, ...
Physical Review B 92 (8), 081114, 2015
29 2015
Characterization of proteins by powder
RB von Dreele
Eleventh European Powder Diffraction Conference: Warsaw, September 19-22 …, 2015
Electronic structure, local magnetism, and spin-orbit effects of Ir (IV)-, Ir (V)-, and Ir (VI)-based compounds
MA Laguna-Marco, P Kayser, JA Alonso, MJ Martinez-Lope, ...
Physical Review B 91 (21), 214433, 2015
127 2015
Fractionalization, entanglement, and separation: Understanding the collective excitations in a spin-orbital chain
CC Chen, M van Veenendaal, TP Devereaux, K Wohlfeld
Physical Review B 91 (16), 165102, 2015
30 2015
Fragility of ferromagnetic double exchange interactions and pressure tuning of magnetism in double perovskite
LSI Veiga, G Fabbris, M Van Veenendaal, NM Souza-Neto, HL Feng, ...
Physical Review B 91 (23), 235135, 2015
47 2015
Ground-state wave function of plutonium in PuSb as determined via x-ray magnetic circular dichroism
M Janoschek, D Haskel, J Fernandez-Rodriguez, M Van Veenendaal, ...
Physical Review B 91 (3), 035117, 2015
13 2015
Hole motion in the Hubbard model
B Moritz, Y Wang, CJ Jia, CC Chen, M van Veenendaal, TP Devereaux, ...
APS March Meeting Abstracts 2015, F25. 001, 2015
Identifying microbial habitats in soil using quantum dots and x-ray fluorescence microtomography
SL O'Brien, MD Whiteside, D Sholto-Douglas, A Dohnalkova, DM Durall, ...
AGU Fall Meeting Abstracts 2015, B23E-0640, 2015
Interaction between x-ray and magnetic vortices
M van Veenendaal
Physical Review B 92 (24), 245116, 2015
27 2015
Macromolecular powder diffraction: Structure solution via molecular
JA Doebbler, RB Von Dreele
3 2015
Maximum a posteriori estimation of crystallographic phases in X-ray diffraction tomography
D Gürsoy, T Biçer, JD Almer, R Kettimuthu, SR Stock, F De Carlo
Philosophical Transactions of the Royal Society A: Mathematical, Physical …, 2015
33 2015
Mixed configuration ground state in iron (II) phthalocyanine
J Fernández-Rodríguez, B Toby, M van Veenendaal
Physical Review B 91 (21), 214427, 2015
31 2015
Physical Review B 92 (7), 075119, 2015
52 2015
Photoinduced Dynamics of Charge Density Waves in Mott-Peierls Systems
Y Wang, CC Chen, C Jia, M van Veenendaal, T Devereaux, B Moritz
APS March Meeting Abstracts 2015, S22. 004, 2015
Practices and standards for data and processing at the APS
BH Toby, D Gürsoy, F De Carlo, N Schwarz, H Sharma, CJ Jacobsen
Synchrotron Radiation News 28 (2), 15-21, 2015
10 2015
Pressure tuning of double exchange in 3d-5d double perovskite Sr2FeOsO6
LSI Veiga, G Fabbris, M van Veenendaal, NM Souza-Neto, HL Feng, ...
arXiv preprint arXiv:1501.07889, 2015
Rapid tomographic image reconstruction via large-scale parallelization
T Bicer, D Gürsoy, R Kettimuthu, F De Carlo, G Agrawal, IT Foster
European Conference on Parallel Processing, 289-302, 2015
50 2015
RIXS and excited states calculation with the Xclaim code
J Fernandez-Rodriguez, B Toby, M van Veenendaal
arXiv preprint arXiv:1508.00762, 2015
Spin chain in magnetic field: limitations of the large-N mean-field theory
K Wohlfeld, CC Chen, M van Veenendaal, TP Devereaux
arXiv preprint arXiv:1504.00996, 2015
2 2015
THE DEVELOPMENT OF GSAS-II
RB Von Dreele
Blucher Physics Proceedings 1 (3), 3-3, 2015
The J1-J2 Kagome Heisenberg Model with Dzyaloshinskii-Moriya Interaction
APS March Meeting Abstracts 2015, Z28. 003, 2015
The many faces of quantum kagome materials: Interplay of further-neighbour exchange and Dzyaloshinskii-Moriya interaction
TF Seman, CC Chen, RRP Singh, M van Veenendaal
arXiv preprint arXiv:1508.01523, 2015
9 2015
Theory of Inelastic Scattering and Absorption of X-rays
M Van Veenendaal
Cambridge University Press, 2015
39 2015
Ultrafast intersystem crossing in nickel porphyrins
J Fernandez-Rodriguez, J Chang, AJ Fedro, M van Veenendaal
arXiv preprint arXiv:1510.08668, 2015
Xclaim: A graphical interface for the calculation of core-hole spectroscopies
J Fernández-Rodríguez, B Toby, M Van Veenendaal
Journal of Electron Spectroscopy and Related Phenomena 202, 81-88, 2015
36 2015
